Fresh installation on two separate sd cards, stuck at "preparing home assistant" screen
Ive formatted and using the Raspberry Pi imager version 1.84 have installed the latest home assistant image and it still seems to get stuck at the same place. I originally used wifi to connect to the internet, but now even using ethernet i get the same issue. See the log below where it gets stuck and sits there for hours. Im installing this on a raspberry pi 3 b+, originally i used a 16gb sd card, then i swapped to a 128gb sd card same issue.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
[__main__] Initializing Supervisor setup
[supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.12.0
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.11.6']
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.10.0
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.10.0
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
[supervisor.plugins.manager] cli does not have the latest version 2023.11.0, updating
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-cli:2023.10.0 to ghcr.io/home-assistant/aarch64-hassio-cli:2023.11.0
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-cli with tag 2023.11.0.
[supervisor.docker.manager] Stopping hassio_cli application
[supervisor.docker.manager] Cleaning hassio_cli application
[supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-cli:2023.10.0']
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
[supervisor.plugins.manager] audio does not have the latest version 2023.12.0, updating
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-audio:2023.10.0 to ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-audio with tag 2023.12.0.
[supervisor.docker.manager] Stopping hassio_audio application
[supervisor.docker.manager] Cleaning hassio_audio application
[supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-audio:2023.10.0']
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 11.2 / BootSlot A
[supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
[supervisor.store.git] Loading add-on /data/addons/core repository
[supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
[supervisor.store] Loading add-ons from store: 72 all - 72 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.12.4
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2023.12.4.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
[supervisor.host.manager] Host information reload completed
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.manager] Cleaning hassio_dns application
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.manager] Cleaning hassio_multicast application
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
[supervisor.docker.manager] Starting homeassistant
[supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
Could be a bad image. Have you tried re-downloading the HA image?
I’m experiencing the same issue on my Raspberry PI 3 B+ on a brand new 64GB SD card.
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.12.4: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.12.4/json: Not Found ("No such image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2023.12.4")
Update - rebooted Pi, tried again and it worked this time!
