Im about to setup FRIGATE and wondering if GitHub - blakeblackshear/frigate-hass-addons: Frigate hass.io addons is best way to go or if I should be looking into something else??
That’s the source…
Thanks. Newbie
For someone that has read 1.3 hours lifetime ( 3 months) in the here in the HA Forum and I read probably 3 times that every day, Did you have a question that is different than is this the link to the official add-on for frigate?
I found this youtube vid to be the most useful in setting up frigate in HA. It uses the blakeblackshear addon. I suspect you may have already watched it.
Or follow the guide in the docs ![]()
Be aware that frigate can use a lot of resources, so be sure to read the hardware recomendations.
