Hi
Due to a major Hard disk failure I’m rebuilding my HA instance
I’ve hit a snag where when trying to set up the Frigate add on to connect to an external Frigate server (That has not changed and was working before the HA server HD failure)
The initial set up creates the addon and is correctly set up with the proxy name, but when viewing the frigate Integration, its showing
cctv.***.co.uk
Failed setup, will retry: Forbidden - insufficient permissions.
the log shows
Forbidden (403) error for URL https://cctv.***.co.uk/api/version: Forbidden
The API is present and happy as navigating to just api the Frigate server returns
Frigate is running. Alive and healthy!
I’m not sure where to go from here, as I saidbefore the firgate server did successfully connect to the old HA server but here it does not want to work.
HA is running under HAOS under Proxmox (Thought I give it ago)
