Frigate AI Notification - Multi-Camera, Include/Exclude Zones, LLMVision, Low Noise
Frigate Home Assistant AI Notification Blueprint
Rewritten and improved version of the original by @zacharyd3.
Frigate AI Notification is a clean, low-noise blueprint for smart multi-camera alerts powered by Frigate and (optionally) LLMVision. It focuses on fast, relevant notifications with the right links and the right amount of detail - no spam.
➤ Import the Blueprint
Under very active development, report bugs & view code on the GitHub page.
:sparkles: Highlights
  • Multi-camera: monitor one or many Frigate cameras from a single automation.
  • Multi-device notifications: send to any number of mobile devices.
  • iOS-optimized playback: uses HLS (.m3u8) for live/clip viewing on iOS when enabled.
  • Action buttons:
    • View Clip opens the event clip
    • View Live deep-links to the camera in HA
    • Open Frigate jumps to Frigate’s review page
    • Silence mute per-camera for X minutes, or globally if you don’t set a table
  • Per-camera silence (optional, recommended): provide an input_text helper to store a tiny JSON map of {camera_slug: muted_until_epoch}.
  • Thoughtful update loop: sends updates on meaningful changes (new snapshot, sub-label change, clip becomes ready) - not for every tiny motion.
  • Zone filtering with wildcards:
    • Include / Exclude lists
    • Match by entered, current, or either
    • Require any or all zones to match
  • Noise controls:
    • Minimum detection score
    • Require “clip ready” (optional)
    • Ignore likely false positives (optional)
  • LLMVision summaries (optional): short, readable descriptions of what happened.
  • Auto URL detection: uses your HA internal/external URL if set; you can override the Frigate UI URL.
  • Friendly titles & camera names: quick options to expand “Cam → Camera” or append “Camera”.
  • Debug mode: safe, verbose logging to validate logic while you fine-tune.
:white_check_mark: Requirements
  • Frigate set up with MQTT events
  • Home Assistant 2024.6+
  • Home Assistant Companion App on your phone (for notifications)
Optional:
  • LLMVision provider (leave blank to disable AI entirely)
  • Input helpers create in the same automation edit screen:
    • input_datetime for a global cooldown (optional, NOT recommended)
    • input_text for the per-camera silence table (optional, recommended)
    • input_boolean as a simple LLM “busy” gate when several cameras run in parallel (optional)
:rocket: Quick Start
  1. Import the blueprint and create an automation from it.
  2. Pick your cameras and notification devices.
  3. (Optional) Turn on iOS Notification if you send to iPhones/iPads — this enables the HLS stream path.
  4. (Optional) Add zones to include/exclude and set match type/logic.
  5. (Optional) Enable LLMVision by selecting a provider/model.
  6. (Optional) Add Global cooldown helper: choose an input_datetime so back-to-back alerts are throttled.
  7. (Recommended) Add Per-camera silence table helper: select an input_text. The blueprint initializes it automatically.
  8. Save and test.
:mobile_phone_with_arrow: How the Notification Behaves
Every send uses the same tag: {{ id }} - the Frigate event id. On both Android and iOS the HA app treats a repeated tag as a replacement of the existing notification rather than a new one. We also set alert_once: true, so the updated notification won’t ping/vibrate again.
The update loop only fires on meaningful changes (clip becomes ready, sub-label changes, zones list changes, or a truly new snapshot). It’s not sending on every MQTT tick.
  • Initial alert on new Frigate event (if it passes your filters).
  • Update alerts on important changes:
    • Clip becomes ready
    • Sub-label recognition changes
    • Zone match list changes - entered/current
    • New snapshot timestamp
  • End alert when the event finishes (optional, depending on your filters).
Buttons you’ll see:
  • View Clip → opens the Frigate clip (or HLS on iOS if enabled)
  • View Live → deep-links to the camera entity in HA
  • Open Frigate → opens /review?camera=...&id=...
  • Silence → mutes just this camera for X minutes (type a number);
    if you didn’t provide a silence table, it falls back to global mute (temporarily turns off this whole automation - all cameras!).
:control_knobs: Zones & Labels — The Simple Version
  • Include list supports * and ?, blank = include all.
  • Exclude list: use to carve out small “privacy” areas inside larger includes. If an event matches both an include and an exclude, the exclude overrides and the notification for that step is suppressed.
Example: include=front_yard_*, exclude=porch_privacy → activity in front_yard_driveway not blocked; stepping into porch_privacy suppresses that tick.
  • Zone Match Type: which zone list to check from Frigate:
    • entered → only after.entered_zones (crossings)
    • current → only after.current_zones (currently inside)
    • either → union of entered + current
  • Zone Logic: when include zones are set, require any or all of the listed zones to match.
    • Example: include=driveway, porch + logic=all → object must be in both zones.
:bell_with_slash: Silence, Cooldowns & Noise Controls
  • Silence button: per-camera mute for X minutes (requires the optional input_text table).
  • Global cooldown: prevents rapid repeat notifications across the board (optional input_datetime).
  • Signal quality filters:
    • Minimum score (default 0.6)
    • Require clip ready
:brain: LLMVision (Optional)
Enable the provider/model to get a short, readable summary of what happened.
You can tweak:
  • Number of frames analyzed
  • Target width (token/size trade-off)
  • Max tokens & temperature
  • Whether to expose images (for richer notifications)
Leave the Provider blank to turn AI off.
:link: Links the Blueprint Builds for You
  • clip_url — the event MP4 (or HLS for iOS if toggled)
  • clip_url_signed — signed clip (used on iOS when available)
  • snapshot_url / thumbnail_url — still images
  • frigate_review_url — jumps to Frigate’s review UI
  • live_deeplink — opens your camera entity in HA
All URLs are auto-derived from your HA internal/external URL when possible. You can override the Frigate UI URL if it lives elsewhere (e.g., different host/port).
Hey! First of all, great rework of @zacharyd3, everything runs smoothly.
However, I’m not getting any summary from LLMVision. Everything seems properly set up, and LLMVision notifications work fine when using their own blueprint.
Any ideas on how I can debug this? What should I look for in the traces?
Thanks in advance :slightly_smiling_face:
v0.3.3 released
I reduced auto per-camera cooldown to 25 seconds so LLMVision summaries are not skipped by the generated silence window.
If nothing changes, please open the automation run trace in Home Assistant. Scroll to the end and confirm whether the LLM Vision: Analyze Frigate Clip service step executed or was skipped/errored; grabbing a screenshot or copy of the step details would be super helpful.
With the trace open, also look at the conditions right before that service call, especially the “camera still silenced” check if you use the per-camera silence table
Finally, check Developer Tools → Logs for any llmvision errors from that same timeframe; share anything you spot so I can narrow this down.
Thanks for this great blueprint. I works for me but I’m not getting the LLMVision summary. I have LLMVision installed and configured but still I’m getting this error:
Frigate AI Notification: Choose at step 9: choice 1: Error executing script. Error for call_service at pos 4: Settings config entry not found. Please set up LLM Vision first.
Frigate AI Notification: Error executing script. Error for choose at pos 9: Settings config entry not found. Please set up LLM Vision first.
Also I’d like to suggest to include blueprint options for changing all message and button text so that other languages could be configured.
And another suggestion: input_boolean helpers to disable/enable notifications, ideally per camera.
I found the issue. For some reason LLM Vision was not configured properly. It now works.
First of all, this is really great! Thanks so much for your hard work on this.
I’m having 1 issue right now. It very well may be User Error, but I’m not finding it. I’m hoping you could help me out. My “exlcude zones” don’t seem to be working as expected. I currently have the “include zones” left blank (i.e. all zones are included), but then under “exclude zones” I just have “Street”.
I have 4 total cameras, 2 at the front of my house and 2 at the back. The two at the front of my house generally look at my driveway and walkway, but can see a bit of the street. I want to exclude the “Street” zone because there’s too many notifications of cars going by.
I double checked that the spelling matches, include case sensitivity. I double checked in Frigate that the events are being tagged with the “Street” zone, and they are. But I am still getting notifications for activity in the street.
Here’s a snippet of my Frigate configuration:
  driveway:
    enabled: true
    ffmpeg:
      inputs:
        - path: <redacted>
          roles: [record]
        - path: <redacted>
          roles: [detect]
    zones:
      Street:
        coordinates:
          -0.001,0.521,0.272,0.359,0.463,0.28,0.539,0.219,0.753,0.232,0.758,0.003,0.2,0.008,0.002,0.159
        loitering_time: 0
      Driveway:
        coordinates:
          0.311,1,0.254,0.653,0.274,0.526,0.331,0.426,0.289,0.357,0.469,0.284,0.776,0.387,1,0.531,1,1
        loitering_time: 0
      Walkway:
        coordinates:
          0.766,0.392,0.842,0.352,0.9,0.344,0.96,0.337,0.964,0.185,0.995,0.212,0.991,0.414,0.959,0.439,0.89,0.454
        loitering_time: 0
I use the GUI to edit the automation from this blueprint, but I did also look at the YAML just to see. This line is at the bottom of the file:
zones_exclude: Street
Do I need quotes or anything anywhere? Did I do something wrong? Are there known quirks that I need to consider? Any help in this would be much appreciated!
What did you configure to fix it?
I deleted my configuration and started from scratch.
This has been working really well for me compared to the OG sgtbatten blueprint. I get instantaneous notifications and sub_labels appear to update 100% of the time. On the other blueprint, notification sub labels do not update for some reason.
What I’d really love to see are some more notification customizations (buttons, title, message). The sgtbatten blueprint really excels in that area.
Thanks for making this!
Thanks, I added an opt-in “Require Zones On Initial Send” so users can suppress early notifications until zones are populated, without changing default behavior.
v0.3.6 released 2/10/26, please update
  • Add optional requirement for zones to be present before the initial notification.
  • Fix mobile notification action - use HA-recommended default handling for missing trigger payloads.
  • Add optional camera override map to match Frigate camera names when HA entity ids differ.
It works great. Thank you for the effort you put in.
One thing to note and I am not sure if this is a problem specific to my setup, I had to significantly increase the maximum tokens, otherwise the Inference would always run into the token limit.
I am using gtp-5 and have it set to 2000 now.
I noticed that the replacing of notifications does not work, it looks like because the tag differs throughout the automation run, in this example:
Automation Run 1:22:34 PM
Executed: February 26, 2026 at 1:23:08 PM
Notification: Person detected
channel: Front Notifications
tag: 1772097754.191555-k0j2v5
group: Front
Executed: February 26, 2026 at 1:23:39 PM
Executed: February 26, 2026 at 1:24:33 PM
Notification: AI Summary
channel: front_notifications
tag: front
group: Front
I am very new to Home Assistant and Frigate. Still just setting up everything after building a Home Assistant OS server on an older Dell Optiplex PC. I have HA and Frigate both set up, and have set up all of the prereqs for this: MQTT, companion apps, LLM Vision.
Is there a way to have it only notify for a person if that person is not identified as one of three ppl I have trained face recognition for?
I also am struggling to understand what input boolean means in this context, after reviewing the info about that feature.
Fixed in 0.3.7
  • Fix LLM notification channel mismatch: LLM summary used {{ camera }}_notifications while initial/update/final used {{ camera_name }} Notifications, preventing Android from replacing the camera card with the LLM summary.
  • Raise default max_tokens from 20 to 100 and expand slider range to 4000; modern models (GPT-5, etc.) need higher limits to avoid truncated summaries.
Input boolean helper:
It's an optional "busy" gate for LLM Vision processing. If you have multiple cameras and events fire close together, the helper ensures only one LLM analysis runs at a time, it waits for the current one to finish before starting the next.
Without it, you could hit rate limits or overload the LLM provider with concurrent calls. To use it, create an Input Boolean helper in HA (e.g. "Frigate LLM Busy") and select it in the blueprint's LLMVision Tweaks section.
For unknown faces:
[0.3.8] Added Suppress Known Faces input (Quality Filters): comma-separated list of recognized face names to silence. Matches against Frigate's sub_label from native face recognition. Applies to initial, update, final, and LLM notifications.
Firstly thanks for making this blueprint! I've been using frigate at a very basic level for ages and have now setup notifications and have the AI description working. Still need to figure out openai pricing as i seem to be using a lot more than i anticipated! Not sure ive got any hardware i can use to setup a local AI.
I do have one question - is it possible to capture the AI description in a log page? currently i just get them as the notification and then they disappear when i click on them.
