Hi everyone, I recently discovered my router reassigned my Home Assistant IP address which caused problems with remote access. I resolved that, but now I’m seeing problems with my Frigate and HACS integrations throwing errors which I’m struggling to resolve.
HACS:
Logger: homeassistant.config_entries
Source: config_entries.py:637
First occurred: 9:17:18 PM (1 occurrences)
Last logged: 9:17:18 PM
Error setting up entry for hacs
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 637, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/hacs/__init__.py", line 220, in async_setup_entry
setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
File "/config/custom_components/hacs/__init__.py", line 206, in async_initialize_integration
await async_try_startup()
File "/config/custom_components/hacs/__init__.py", line 193, in async_try_startup
startup_result = await async_startup()
File "/config/custom_components/hacs/__init__.py", line 171, in async_startup
hass.config_entries.async_setup_platforms(
AttributeError: 'ConfigEntries' object has no attribute 'async_setup_platforms'. Did you mean: 'async_unload_platforms'?
Frigate integration:
First occurred: 9:17:19 PM (2 occurrences)
Last logged: 9:17:41 PM
Error setting up entry 192.168.1.160:5000/ for frigate
File "/config/custom_components/frigate/__init__.py", line 280, in async_setup_entry
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2272, in async_forward_entry_setups
await integration.async_get_platforms(platforms)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1185, in async_get_platforms
import_future.result()
[Previous line repeated 3 more times]
File "/usr/src/homeassistant/homeassistant/loader.py", line 1173, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1098, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1272, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1304, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/frigate/sensor.py", line 8, in <module>
from homeassistant.const import CONF_URL, PERCENTAGE, TEMP_CELSIUS
ImportError: cannot import name 'TEMP_CELSIUS' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py)
