Frigate camera entities do not seem to support recording or streaming
I used (i guess with regular old, camera entities setup in my configuration.yaml) be able to stream and record these. I’ve since done a way with these in favour of frigate camera entities, but it seems i can’t do any of these actions those.
I guess they don’t have the source set for some reason (I understand this is the problem from a bit of browsing; the message i get is: This camera does not support stream or record message).
Any idea’s why this is the case? I’d rather not have more camera entities again as this fills up my homepage with redundant camera entities (not to mention load up my cpu/nvr/frigate with additional RTSP feeds).
Any way of setting the source on these frigate entities?
I believe i need to turn on RTMP, will report back once i know more.
In frigate 0.11 RTMP is required for this, in frigate 0.12 the new RTSP restream is required for this
