Frigate go2rtc
I used Frigate add camera wizard. Which worked, but maybe not optimal?
The cameras were added within the main yaml config.
inputs:
    - path: rtsp://xxxxxxxx:[email protected].##.##:554/Preview_01_main
And are working. But with frame drops.
At the very end of the yaml config the same inputs are indicated under the go2rtc streams section.
But with ffmpeg: before.
Am I supposed to use the go2rtc streams as the inputs or is this properly indicating that go2rtc is set up right and some other issue is dropping a lot of frames.
The feed does show dropped frames when viewing. Stuttering.
[Frigate Documentation pages](https://docs.frigate.video/ ) might help and
blakeblackshear/frigate · Discussions · GitHub is the official Frigate support hub and is another good place to get help with Frigate if you don’t get an answer here.
