Frigate integration not available for configuration
I am trying to test frigate. The server will Not be hosted on my Home Assistant installation.
  • HA core-2021.12.8
  • Frigate integration 2.2
The first step I did was to install the integration via HACS store. Next I rebooted.
Now I am trying to configure the integration, but when I try to install it, it does not show up. I can see that I have a warning at boot time from HA saying that is it not an official integration, so I guess HA is seeing it properly at boot.
What am I missing? What should I look for?
Log (which looks okay given it was installed via HACS):
2022-01-10 20:59:59 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
custom_components content:
Not found when trying to setup:
OK so…
I reinstalled the integration via HACS, restarted another time HA… not working. Forgot about it and 30 minutes later I came back and now am I able to configure it.
Not sure exactly what happened, maybe the reinstallation made something.
Solved.
Had a similar problem and found this thread. Mine ended up being a browser issue. Worked after clearing cookies (hard refresh) then logging back in.
