Moved my Ubuntu VM ( wich contain my frigate docker ) , so reconfigure ip of frigate proxy and addon, but now addon refuse to connect ( proxy is ok )
HAOSS : raspi 192.168.0.10
Frigate : docker on Ubuntu host 192.168.0.6
2022-06-22 22:46:09 ERROR (MainThread) [custom_components.frigate.api] Error fetching information from http://192.168.0.6:5000/api/stats: 500, message='INTERNAL SERVER ERROR', url=URL('http://192.168.0.6:5000/api/stats')
- if i test : http://192.168.0.6:5000/api i got
Frigate is running. Alive and healthy!
- if i test : http://192.168.0.6:5000/api/stats i got
Internal Server Error
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
- Ping from HAOS to my Ubuntu VM :
| | | | /\ (_) | | | |
| |__| | ___ _ __ ___ ___ / \ ___ ___ _ ___| |_ __ _ _ __ | |_
| __ |/ _ \| '_ \ _ \ / _ \ / /\ \ / __/ __| / __| __/ _\ | '_ \| __|
| | | | (_) | | | | | | __/ / ____ \\__ \__ \ \__ \ || (_| | | | | |_
|_| |_|\___/|_| |_| |_|\___| /_/ \_\___/___/_|___/\__\__,_|_| |_|\__|
Welcome to the Home Assistant command line.
System information
IPv4 addresses for eth0: 192.168.0.10/24
IPv6 addresses for eth0: 2a01:e0a:3c5:8d90:840:e0aa:1de4:39a5/64, fe80::81d7:a7e6:50c8:8f62/64
IPv4 addresses for wlan0:
OS Version: Home Assistant OS 8.2
Home Assistant Core: 2022.6.7
Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357
β ~ ping 192.168.0.6
PING 192.168.0.6 (192.168.0.6): 56 data bytes
64 bytes from 192.168.0.6: seq=0 ttl=64 time=0.799 ms
64 bytes from 192.168.0.6: seq=1 ttl=64 time=0.634 ms
64 bytes from 192.168.0.6: seq=2 ttl=64 time=0.763 ms
64 bytes from 192.168.0.6: seq=3 ttl=64 time=0.631 ms
^C
--- 192.168.0.6 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 0.631/0.706/0.799 ms
- Frigate Docker Compose ( changed nothing )
version: "3.8"
services:
frigate:
container_name: frigate
privileged: true
restart: unless-stopped
image: blakeblackshear/frigate:stable-amd64
shm_size: "64mb"
devices:
- /dev/dri/renderD128
volumes:
- /etc/localtime:/etc/localtime:ro
- $PWD/data/config.yml:/config/config.yml:ro
- /mnt/drives/docs/_FRIGATE/:/media/frigate
- $PWD/data/db:/db
- type: tmpfs
target: /tmp/cache
tmpfs:
ports:
- "5000:5000"
- "1935:1935"
environment:
- PUID=1005
- PGID=1007
- TZ=Europe/Paris
- FRIGATE_RTSP_PASSWORD= "xxxxx"
Telnet from another computer ( 192.168.0.2 ) βtelnet 192.168.0.6:5000β connected successfully
Proof of the correct IP and frigate running :
Tested with blakeblackshear/frigate:0.11.0-beta4 same problem
Tested with addon v2.3 & 3.0.0 rc2, same error, I will go crazy ^^
Any idea ? thanks !
