Getting everytime
frigate.comms.mqtt ERROR : Unable to connect to MQTT server: Invalid host.
strange thing using the same password and username as my HA-agent on the pc. and info to pc and receiving is working correctly.
To be able to get notification to work, first need this to work
getting a bit further whit it in the mean time.
even if it does not ask at it on the site of frigate, but needed to fit host also in. atleast that error seems to be gone if i see correct.
but the next one stay there
Unable to publish to stats: client is not connected
well there’s your problem, you’re trying to give it the home assistant frontend as the mqtt host which is incorrect. It also should not include the protocol
