Jcarlier
(Carlier Jacques)
June 4, 2025, 4:44pm
1
hi,
I accidentally deleted the Frigate item from the lateral sidebar.
Frigate (full access) is installed via add-on (not by integration) .
I reinstalled the add-on with the option to display it in the sidebar and restart HA, but I still can’t find it in the sidebar.
How can I restore this item?
THANKS
Long Press the top right part of the Sidebar, where it says “Home Assistant”:
This will make your sidebar editable - scroll down and you will find Frigate. Press +
to add it back, then move it to the position you like
Alternatively, you can click your profile icon in the bottom left of the sidebar, then click Edit on “Change the order and hide items from the sidebar” under Browser settings section
Jcarlier
(Carlier Jacques)
June 5, 2025, 7:36am
3
ok THANKS for your support
