Frigate Mobile App Notifications 2.0
Can anyone else confirm with the latest stable and IOS device?
@sgtbatten how i can chose the righ version of blueprint for ios ?
I have a problem with version 0.6 (stable - without Telegram). On the earlier version it worked ok (i.e. movement on camera A is a notification from reaction A). On the new version (12.0.6 with Telegram) it continues to work + Telegram, but in the Automation section I have a sign that despite setting a notification for camera A and receiving a notification on camera A - in the running actions I have automation A, B, C and D running. I have no idea why this is the case.
I have it set up this way, on the grounds that movement in a particular camera is supposed to set off the light within it. What I have now is that the notifications work fine - but the automation dependent on them no longer (i.e. detects movement of camera B, and turns on the light in D). They are well configured, but in the Automations I have that each action has triggered (i.e. 2x for camera A, 2x for camera B, etc.). I donā€™t really know how to solve this, as the configurations apart from adding Telegram are not changed.
They are all meant to work, Iā€™m trying to confirm that by getting feedback from you guys
Iā€™m not quite sure what you are saying sorry.
Will need some examples and clearer description.
Thanks for quick response. The main question - this situation (on the screen) is ok (all blueprints were run during recognise human on Camera 1):
Becasue - the notification works well. Camera 1 recognize human and I get notice that Camera 1 recognized human. If it is ok - I need change or prepare new automation for lights per each camera.
Is anyone able to confirm an issue im facing on seemingly all versions of the blueprint.
I no longer (or perhaps 95% of the time at least) get the message attached to my notification.
Now i know the current published versions have some issues, which iā€™ve been working on non-stop for days but the thing holding me up is this message issue. If i use the title, it works, if i use message which we have always used here it suddenly doesnā€™t appear as part of the notification, just the image and no text. Am i having an issue with my devices or is anyone else seeing this?
Hello, Iā€™m using the frigate 0.14 beta and have therefore installed the beta from the 0.14 branch. (0.14.0.2k) I now get the error message Message malformed: Missing input master_condition
Blockquote
description: ā€œā€
alias: Frigate Notifications (0.14.0.2k)
use_blueprint:
path: SgtBatten/Beta 14.yaml
input:
camera:
- camera.einfahrt
- camera.haustuer
notify_device: e1651d4801d3560ee8e9f5d11a2cf9dc
notify_group: familie
Blockquote
Hello SgtBatten, thank you very much for this really helpful blueprint.
Frigate categorizes review items as Alerts and Detections. By default, all person and car objects are considered Alerts. You can refine categorization of your review items by configuring required zones for them.
I use the latest Home Assistant version, the latest version of Frigate and the Blueprint. The clips are played on an iPhone (IOS)
I have set up a zone in Frigate, so when someone enters it, I want it to be given as an Alert and not as a detection. But if I set this up, I wonā€™t be able to watch any clips if itā€™s detected anything again. So otherwise my Frigate instance was opened when I went to the notification and the video was played. The browser opens when I tap on the notification and I get the error: {ā€œmessageā€:ā€œClip not availableā€,ā€œsuccessā€:false" from doorbell
I hope that there might be an explanation for this. Thanks in advance.
The problem Iā€™m still having is: 1)sometimes I get that weird text in the notification box (instead of a snapshot of the person) on my iPhone. I noticed when this happens, thereā€™s no event to review in Frigate 2)most of the time, I get the correct notification with a snapshot in the notification and when I go to Frigate, I see the associated event playing 3)sometimes I get 2 notifications (back to back,) 1 being the expected notification, then a 2nd one with no snapshot at all in the notification and no associated event. Most of the time everything is working fine, but I am still getting (mainly) the sporadic issue in #1 above.
Iā€™m very close to releasing the reviews version as beta. The past week Iā€™ve been focusing on one bug and lots of Quality of Life improvements.
As an example iā€™ve got most conditions labelled now so itā€™s easy to see what the false condition actually was.
The blueprint can now handle detections that become alerts. and you can actually enable detections and alerts simultaneously if desired.
Iā€™ve moved some conditions around in the tree to remove duplication and cleaned up the yaml a lot (though itā€™s still a mess i know).
You will need to start a fresh automation if you experience any issues as many inputs have changed
This is exciting!
Thanks! Looks good, I am getting no image attachment when using bounding box snapshot. Snapshot without works fine though. Latest .14x beta.
I fixed something about an hour ago related to this. are you on r or s?
For me no thumbnail and video are attached. I use the version ā€œrā€
Ah! Was on r. Iā€™ll update and report if still having issues! Thanks!
with the new version it works again
I found another error, I only activated ā€œAlertsā€ in the Blueprint but I still get a notification for detections.
Trace Log:
Iā€™m still on G. Where do I find these updates?
you have to go to the 0.14 branch and download the beta there or the contents of the beta and then upload it to the blueprint folder on Home Assistant, or replace the contents of the existing yaml file with the contents
