I installed the the frigate addon and integration and the frigate log files are showing
[](<[2022-12-31 19:54:30] frigate.mqtt ERROR : Unable to connect to MQTT server: MQTT Not authorized>)
I have tried using both the loopback address and LAN IP, I also removed the MQTT birth field but get the same result. At first I had added mqtt/mqtt as a home assistant user but have since deleted it and added it to the config. Any ideas? Also worth noting the recordings dont work, Im not sure if that is related.
Happy New Year and thanks in advance
System
Home Assistant 2022.12.8
Supervisor 2022.12.1
Operating System 9.4
Frontend 20221213.1 - latest
Running on odroid N2+
Frigate Config
host: 127.0.0.1
user: user
password: password
cameras:
Test_cam:
ffmpeg:
inputs:
- path: rtsp://frigate:[email protected]:554/axis-media/media.amp?streamprofile=frigate
roles:
- detect
- clips
- record
width: 1280
height: 720
fps: 5
objects:
track:
- person
record:
enabled: True
detectors:
coral:
type: edgetpu
device: usb>)
MQTT Broker config
logins:
- username: user
password: password
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
