Frigate: No Audio (neither live stream nor recording)
Hi all,
I’ve recently gotten started using Frigate and it mostly works great, with a few hick-ups along the way.
BUT: I just cannot get audio to work. Neither in the recordings nor in the live stream, it’s just always without sound.
I’m checking the streams/audio straight from within Frigate, so definitely not a card issue or similar.
  • I’ve tried the frigate addon as well as a standalone frigate server running on docker
  • I’ve tried a Reolink cam as well as multiple Tapo cams
  • I’ve checked the stream in the reolink/tapo apps where I do get audio
  • I’ve checked the stream from within VLC where I do get audio
This is my frigate.yml/config.yml:
mqtt:
  enabled: true
  host: xxx.xxx.x.x
  user: username
  password: password
  topic_prefix: frigate
  client_id: frigate
  stats_interval: 60
# Optional: Detectors configuration. Defaults to a single CPU detector
detectors:
  # Required: name of the detector
  cpu:
    type: cpu
ffmpeg:
  hwaccel_args: preset-vaapi
  output_args:
    record: preset-record-generic-audio-aac
birdseye: [removed, likely irrelevant]
objects: [removed, likely irrelevant]
snapshots: [removed, likely irrelevant]
timestamp_style: [removed, likely irrelevant]
go2rtc:
  streams:
    Wohnzimmer:
      - rtsp://username:[email protected]:554/stream1
      - "ffmpeg:wohnzimmer#audio=aac"
    Wohnzimmer_sub:
      - rtsp://username:[email protected]:554/stream2
cameras:
  Wohnzimmer:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/Wohnzimmer
          input_args: preset-rtsp-restream
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/Wohnzimmer_sub
          roles:
            - detect
    onvif: [removed, likely irrelevant]
    detect:
      width: 640
      height: 360
      fps: 5
    record:
      enabled: true
      retain:
        days: 5
      alerts:
        retain:
          days: 30
      detections:
        retain:
          days: 30
version: 0.15-1
I feel like I’ve done exactly what is written in the documentation and what is recommended in other similar forum posts.
Can you help me fix this?
ok so I have no idea what happened, but I suddenly have audio in the live stream. I only added a second camera and restarted frigate.
But I still don’t have audio in my recordings.
Change:
cameras:
  Wohnzimmer:
    ffmpeg:
      inputs:
          roles:
            - record
to:
cameras:
  Wohnzimmer:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/Wohnzimmer?audio&video
          roles:
            - record
that seems to have worked, thanks! I’ll keep watching this and might report back if I’m experiencing any issues :slight_smile:
@Tamsy
Do you maybe have some more expert insight for me with the other config I tried (HA addon)?
I got audio in recordings working with this
ffmpeg:
  output_args:
But there is still no sound in the live view despite having go2rtc configured.
I’ve also noticed that the live stream is extremely bad quality - it seems as if it’s taking the detect stream instead of the record stream.
mqtt:
  enabled: true
  host: core-mosquitto
  user: user
  password: pw
  client_id: frigate
  stats_interval: 30
detectors:
    type: cpu
ffmpeg:
  hwaccel_args: preset-rpi-64-h264
  output_args:
go2rtc:
  streams:
   # reolink cam, according to ffprobe has an aac audio stream
    kinderzimmer:
      - rtsp://username:[email protected]:554/h265Preview_01_main
    kinderzimmer_sub:
      - rtsp://username:[email protected]::554/h265Preview_01_sub
    # tapo cam, according to ffprobe has a pcm_alaw audio stream
    kueche:
      - rtsp://username:[email protected]::554/stream1
      - ffmpeg:kueche#audio=aac
    kueche_sub:
      - rtsp://username:[email protected]::554/stream2
cameras:
  Kinderzimmer:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/kinderzimmer?audio&video
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/kinderzimmer_sub
          roles:
            - detect
    detect:
      width: 640
      height: 480
      fps: 7
    record:
      enabled: true
      retain:
        days: 5
      alerts:
        retain:
          days: 30
      detections:
        retain:
          days: 30
    motion:
      mask: 0,-0.001,0,0.059,0.316,0.057,0.316,0
  Kueche:
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/kueche?audio&video
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/kueche_sub
          roles:
            - detect
    detect:
      width: 640
      height: 360
      fps: 5
    record:
      enabled: true
      retain:
        days: 5
      alerts:
        retain:
          days: 30
      detections:
        retain:
          days: 30
version: 0.15-1
Just add ?audio&video to the detect-stream like you did with the record-stream like this:
cameras:
  Wohnzimmer:
    ffmpeg:
      inputs:
          roles:
            - record
        - path: rtsp://127.0.0.1:8554/Wohnzimmer_sub?audio&video
          roles:
            - detect
Then add:
    live:
      stream_name: Wohnzimmer
to define the record-stream for live view.
The W should be capitalized
It seems I’ve gotten it to work, thank you @crzynik and @Tamsy !!
I’ve changed everything to first-letter-capitalized just to make sure it’s the same everywhere, I added audio&video to the detect stream, plus I’ve also noticed through ffprobe that my streamy are h264, not h265 (I had initially followed a guide). With this it seems that setting the live stream manually isn’t even necessary anymore :slight_smile:
I made a couple changes at ones, to not sure which accounted to what, but this seems to be it - again, thank you so much! Slowly getting the hang of this :smiley:
