Frigate NVR Add-on doesn't start
I am setting up a new HA on a old Lenovo Mini PC, installed HA OS and now wanted to setup Frigate NVR Full Access. Everything incl. config is setup but when I start Frigate, I get the following supervisor logs entry:
24-03-11 10:33:16 ERROR (SyncWorker_9) [supervisor.docker.manager] Can’t start addon_ccab4aaf_frigate-fa: 500 Server Error for http+docker://localhost/v1.43/containers/e0eeee8d50addb17be8dbe7d22748284bb0448dfc4aa8526aa2016100814d678/start: Internal Server Error (“driver failed programming external connectivity on endpoint addon_ccab4aaf_frigate-fa (c8b261f6f0c26f79eb852863af37fef9d8b967b74148457de6a0b62b415be9ff): Error starting userland proxy: listen tcp4 0.0.0.0:8555: bind: address already in use”)
Not sure what it is saying :wink:
Found the issue. Also setup go2rtc and that was using port 8555. Had to turn that off and then the error resolved :slight_smile:
