Frigate NVR proxy with nginx reverse proxy
I have HassOS as VM under proxmox, I also have a nginx VM as reverse proxy for the different services I am hosting
I’ve installed frigate as a docker container inside a LXE container. And integrated it to Hass with the Frigate NVR proxy add-on.
The issue is when i access Hass from its FQDN (https://hass.foo.bar/ccab4aaf_frigate-proxy/dashboard) I cannot access frigate from the Hass sidebar. I believe that is because the add-on create a nginx reverse proxy with these parameters:
    location / {
        allow   172.30.32.2;
        deny    all;
Denying access to my reverse proxy
I my case I guess I would need:
    location / {
        allow   172.30.32.2 [reverse-proxy-ip-address];
        deny    all;
What would be the best approach to do this since HassOS is pretty closed down?
