Frigate: Problem of using VLC as rtsp streamer to Frigate
Hi …
So basically I want to use VLC as camera stream for Frigate.
One thing I notice is that VLC is a bit picky about the last slash in the path.
for example:
rtsp://192.168.1.1:8554/test/
is okay but
is not.
I can view my VLC stream with (on client where I send the stream with vlc)
ffplay “rtsp://192.168.1.1:8554/test/”
I can also view my stream on my phone (with vlc app) so its not a firewall issue.
But when using the same stream in Frigate …
 cameras:
   vlc:
     enabled: True
     ffmpeg:
       inputs:
         - path: rtsp://192.168.1.1:8554/test/
I get in the system log
rtsp://192.168.1.1:8554/test/: Protocol not supported
Anyone have a clue of what’s the problem ?
Add go2rtc in your frigate config and test with that
Its the same …
Its seems that VLC doesn’t respond correctly …
warning
2025-01-29 20:07:16
rtsp
error="streams: dial tcp 192.168.1.174:8554: i/o timeout" stream=vlc
info
2025-01-29 20:07:17
startup
Starting go2rtc healthcheck service...
info
2025-01-29 20:07:38
streams
can't get track error="wrong response on SETUP"
warning
2025-01-29 20:07:38
rtsp
error="streams: wrong response on SETUP" stream=vlc
info
2025-01-29 20:07:57
streams
warning
2025-01-29 20:07:57
rtsp
info
2025-01-29 20:08:07
streams
warning
2025-01-29 20:08:07
rtsp
Seems that using vlc as rtsp server is a dead end …
Finally found out what the problem was.
It was the input_args in Frigate.
VLC is sending rtsp in UDP. You can change this behaviour under Tools → preferense → (show all) → Input → Demuxer → RTSP but for simplicity its easier just to use correct input_arg.
In my case …
cameras:
  vlc:
    enabled: True
    ffmpeg:
      inputs:
        - path: rtsp://192.168.1.174:8554/test
          input_args: preset-rtsp-udp
