Frigate: problem with notifications
I’ve been experiencing an issue with Telegram notifications since last week. I’m not sure why, but the “official” automation used to send notifications on Telegram (as described on the Frigate website) is no longer working.
When I check the logs, I can see that the automation fails with the following error:
“UndefinedError: ‘dict object’ has no attribute ‘payload_json’”.
I can confirm that:
  • Alerts on Frigate and Frigate works fine ;
  • MQTT server works ;
  • Telegram bot works ;
  • I am using “frigate/events” and I can see this topic on mqtt ;
Any idea on whats going on ?
Many thanks for your help.
Here is the automation:
  alias: '[Notify] - Send picture to telegram'
  description: Send picture to telegram
    - platform: mqtt
      topic: frigate/events
  condition:
    - condition: template
      value_template: '{{ trigger.payload_json["type"] == "end" }}'
      value_template: '{{ trigger.payload_json["after"]["entered_zones"].count("right") > 0 }}'
    - condition: state
      entity_id: input_boolean.stop_camera_notification
      state: 'off'
    - delay:
        hours: 0
        minutes: 0
        seconds: 1
    - service: telegram_bot.send_photo
      data_template:
        message: Détection caméra on right
          photo:
            - url: >-
                http://myhaip:8123/api/frigate/notifications/{{trigger.payload_json["after"]["id"]}}/snapshot.jpg
              caption: >-
                "Message"
    - service: homeassistant.turn_on
      entity_id: input_boolean.helper_detection_cam
    - delay: "00:00:02"
    - service: homeassistant.turn_off
  mode: single
  initial_state: true
