Frigate proxmox. How?
I am going through a tough time of getting far with this. I initially installed from here Proxmox VE Helper-Scripts
It added i believe something called openvino and ran really quickly (i tried frigate a year or so ago but it was painful and slow).
This version isnt a docker version though so i was having issues making changes as i didnt really know what i was doing other than following outdated YT vids.
I see theres now a v15.1.
My question therefore is, can i find a script, or a simple instruction on getting up and running with a version that has docker and openvino?
As far as I know openvino works out of the box using the script.
But the script will install version 14.something. The script will skip version 15 going straight to 16.
If you want to use docker, install the script for docker and then install frigate.
Ok great so to clarify, firstly install docker, then once installed, run the script which i referred to. I dont need latest version just one that works.
no no no.
Either you install the script you mentioned or you install the script for docker and install frigate manually
Ahh, but that script had openvino built in but no docker so i am cant use the compose command when i mske changes. Sorry i appreciate this is likely s stupid question.
If you are using Windows, you can use winscp to edit the configuration file if you have problems accessing the UI.
Thanks for your help im using AI Gemini to help. Im on proxmox/Debien. Thanks very much for your help though. Ill see where i get to from here.
