I am a little lost as to how to enable hardware acceleration on Frigate.
I have two IP cameras with H.264 stream through RTSP (unfortunately I can’t change it to H.265, it’s a cheap Chinese camera).
As I understand, RPi 5 doesn’t have hardware H.264 decoding.
Is there any other way to enable hardware acceleration?
Right now the CPU gets easily gets to 50-85% with just frigate running…
I thought about converting H.265 to H.264 but that’ll be also CPU intensive I guess.
Please help!
This is my config.yml:
mqtt:
enabled: true
host: pi.local
port: 1883
topic_prefix: frigate
cameras:
entrance:
ffmpeg:
inputs:
- path: rtsp://... #low-res stream
roles:
- detect
- path: rtsp://... #high-res stream
roles:
- record
detect:
enabled: true
width: 640
height: 360
fps: 5
record:
enabled: true
retain:
days: 0
alerts:
retain:
days: 3
detections:
retain:
days: 3
snapshots:
enabled: true
retain:
default: 7
motion:
threshold: 30
contour_area: 10
improve_contrast: true
objects:
track:
- person
backyard:
ffmpeg:
inputs:
roles:
- detect
roles:
- record
detect:
enabled: true
width: 640
height: 360
fps: 5
record:
enabled: true
retain:
days: 0
alerts:
retain:
days: 3
detections:
retain:
days: 3
snapshots:
enabled: true
retain:
default: 7
motion:
threshold: 30
contour_area: 10
objects:
track:
- person
version: 0.15-1
And this is how I run Frigate in Docker:
docker run -d --name frigate \
--privileged \
--restart=unless-stopped \
--shm-size=74m \
--mount type=tmpfs,target=/tmp/cache,tmpfs-size=128000000 \
-v ~/frigate/config:/config \
-v ~/frigate/media:/media/frigate \
-v /etc/localtime:/etc/localtime:ro \
-p 5000:5000 \
--device /dev/dri:/dev/dri \
ghcr.io/blakeblackshear/frigate:stable
