Hello
I have problem with frigate, after upgrade HA to 2025.6 frigate stoper working, i tryed reinstal and still not working:(
Propably its problem with go2rtc, but idk how IT solve,
Im looking for any tutorial how to co figurę frigate with go2rtc on newest HA version
How can i check if go2rtc works good in my HA instalation?
Ty for any help
any logs will help us help you
frigate bundles go2rtc. better to use that if you use frigate
having both running will not have effect on frigate. Frigate will connect to whichever go2rtc instance is configured in its config file.
go2rtc in frigate has a UI.
I do not know how to access it if you are running HAOS (i use docker) but it may be hostip:1984
upgrade from what version?
Did you also upgrade frigate?
I have nevest frigate version (full Access), updated HA from 2025.5 to 2025.6.
Should i config something in HA to run native go2rtc?
You need to add full camera config to go2rtc in frigate or HA. Do not add camera to both, not because it will break things but more because it will create unneeded connections to camera.
Full config in one
The other points to the go2rtc instance with full config
If you previously set up cameras in go2rtc in frigate you only need to add below into HA config substituting your frigate IP
Example from docs
go2rtc:
url: http://my-go2rtc-instance:1984
