Frigate suddemly eating all my prosessor power?
i am unsure what is happening as i hae been running frigate for some time now perfectly fine but at some point it has started to use a LOT of my cpu usage i have tried restarting the add on and rebboting the home assistant sertver to no use i am unsure whats causing it or when it started as nothing has changed since it was last running fine
check the frigate system page and see what is using cpu
not the devices i think? so im not sure what to do about this
It is your object detector because you’re not using a coral or GPU like is recommended.
i dont know what that means or how to change it it was running fine last night nothing has changed?
