I just receive my new camera Reolink RLC-520A, it’s directly added to HA by Reolink integration.
But I have some difficulties to add it to Frigate.
Here my conf file :
## Connection à MQTT ##
mqtt:
host: XxX
port: XxX
client_id: XxX
topic_prefix: XxX
user: XxX
password: XxX
## Choix des caméras ##
go2rtc:
streams:
# r4252_smart_outdoor_camera:
# - echo:bash /config/custom_components/expose_camera_stream_source/get_stream.sh
# camera.r4252_smart_outdoor_camera
camera_reolink_jardin:
- rtsp://XxX:XxX@IP:554/h264Preview_01_main
# if you want to decode a h265 (hevc) stream
#ffmpeg:
# hwaccel_args: preset-rpi-64-h264
## Liste des caméras avec leurs adresses de connection ##
cameras:
# ffmpeg:
# inputs:
# - path: rtsp://127.0.0.1:8554/r4252_smart_outdoor_camera?video
# # test - path: rtsp://127.0.0.1:18554/r4252_smart_outdoor_camera?video
# #input_args: preset-rtsp-restream-low-latency
# input_args:
# - -rtsp_transport
# - tcp
# roles:
# - detect
# motion: ## Création des zones à ignorer ##
# motion:
# mask:
## Choix des options de détection et d'enregistrement ##
# motion:
# threshold: 30
# contour_area: 10
# improve_contrast: "true"
# mask:
# - 0.4,0.093,0.401,0.042,0.368,0.045,0.372,0.094
# - 0.818,0.996,0.586,1,0.485,0.788,0.488,0.727,0.597,0.736,0.596,0.679,0.583,0.521,0.542,0.525,0.541,0.427,0.58,0.464,0.562,0.272,0.432,0.231,0.398,0.188,0.408,0.139,0.538,0.171,0.691,0.201,0.707,0.405,0.678,0.497,0.684,0.551,0.733,0.456,0.767,0.465,0.782,0.514,0.796,0.562,0.772,0.582,0.761,0.615,0.743,0.652,0.761,0.679,0.763,0.737,0.74,0.755,0.717,0.762,0.744,0.815,0.747,0.833,0.788,0.891
ffmpeg:
inputs:
- path: rtsp://127.0.0.1:8554/camera_reolink_jardin?video
input_args:
- -rtsp_transport
- tcp
roles:
- detect
- record
detect:
enabled: true
motion:
threshold: 25
contour_area: 10
record:
enabled: true
retain:
days: 3
mode: all
snapshots:
enabled: true
objects:
track:
- person
- dog
record:
enabled: true
retain: # Durée de rétention des enregistrements
days: 3
mode: all
alerts:
retain:
days: 15
pre_capture: 60
post_capture: 60
detections:
retain:
days: 15
pre_capture: 60
post_capture: 60
objects:
# Optional: list of objects to track from labelmap.txt (default: shown below)
track:
- person
- dog
- cat
# Optional: filters to reduce false positives for specific object types
filters:
person:
# Optional: minimum width*height of the bounding box for the detected object (default: 0)
min_area: 15000
# Optional: maximum width*height of the bounding box for the detected object (default: 24000000)
# max_area: 100000
# Optional: minimum width/height of the bounding box for the detected object (default: 0)
# min_ratio: 0.5
# Optional: maximum width/height of the bounding box for the detected object (default: 24000000)
# max_ratio: 2.0
# Optional: minimum score for the object to initiate tracking (default: shown below)
min_score: 0.6
# Optional: minimum decimal percentage for tracked object's computed score to be considered a true positive (default: shown below)
threshold: 0.8
dog:
# min_area: 5000
# max_area: 100000
# min_ratio: 0.5
# max_ratio: 2.0
min_score: 0.5
threshold: 0.6
# Optional: mask to prevent this object type from being detected in certain areas (default: no mask)
# Checks based on the bottom center of the bounding box of the object
# mask: 0,0,1000,0,1000,200,0,200
cat:
# min_area: 5000
# max_area: 100000
# min_ratio: 0.5
# max_ratio: 2.0
min_score: 0.5
threshold: 0.6
motion:
# Optional: The threshold passed to cv2.threshold to determine if a pixel is different enough to be counted as motion. (default: shown below)
# Increasing this value will make motion detection less sensitive and decreasing it will make motion detection more sensitive.
# The value should be between 1 and 255.
threshold: 20
improve_contrast: "false"
# Optional
ui:
# Optional: Set the default live mode for cameras in the UI (default: shown below)
timezone: Europe/Paris
# Optional: Use an experimental recordings / camera view UI (default: shown below)
# use_experimental: False
# Optional: Set the time format used.
# Options are browser, 12hour, or 24hour (default: shown below)
#time_format: browser
# Optional: Set the date style for a specified length.
# Options are: full, long, medium, short
# Examples:
# short: 2/11/23
# medium: Feb 11, 2023
# full: Saturday, February 11, 2023
# (default: shown below).
# date_style: short
# Optional: Set the time style for a specified length.
# Examples:
# short: 8:14 PM
# medium: 8:15:22 PM
# full: 8:15:22 PM Mountain Standard Time
# time_style: medium
# Optional: Ability to manually override the date / time styling to use strftime format
# https://www.gnu.org/software/libc/manual/html_node/Formatting-Calendar-Time.html
# possible values are shown above (default: not set)
# strftime_fmt: "%Y/%m/%d %H:%M"
# Detecteur Google Coral
detectors:
coral:
type: edgetpu
device: usb
enabled: true
# deepstack:
# api_url: http://192.168.1.136:32168/v1/vision/detection
# type: deepstack
# api_timeout: 0.1 # seconds
#detectors:
# cpu1:
# type: cpu
snapshots:
enabled: true
version: 0.15-1
And the error log :
ffmpeg.camera_reolink_jardin.detect
Message
Error opening input file rtsp://127.0.0.1:8554/your_reolink_camera_sub.
2025-04-18 14:24:28.016841378 [2025-04-18 16:24:28] watchdog.camera_reolink_jardin ERROR : Ffmpeg process crashed unexpectedly for camera_reolink_jardin.
2025-04-18 14:24:28.016881003 [2025-04-18 16:24:28] watchdog.camera_reolink_jardin ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2025-04-18 14:24:28.016993429 [2025-04-18 16:24:28] ffmpeg.camera_reolink_jardin.detect ERROR : [rtsp @ 0x560954c46f40] method DESCRIBE failed: 404 Not Found
2025-04-18 14:24:28.016995903 [2025-04-18 16:24:28] ffmpeg.camera_reolink_jardin.detect ERROR : [in#0 @ 0x560954c46bc0] Error opening input: Server returned 404 Not Found
2025-04-18 14:24:28.017011012 [2025-04-18 16:24:28] ffmpeg.camera_reolink_jardin.detect ERROR : Error opening input file rtsp://127.0.0.1:8554/your_reolink_camera_sub.
2025-04-18 14:24:28.017053473 [2025-04-18 16:24:28] ffmpeg.camera_reolink_jardin.detect ERROR : Error opening input files: Server returned 404 Not Found
2025-04-18 14:24:28.034958852 [2025-04-18 16:24:28] watchdog.camera_reolink_jardin ERROR : No new recording segments were created for camera_reolink_jardin in the last 120s. restarting the ffmpeg record process...
2025-04-18 14:24:28.035032073 [2025-04-18 16:24:28] watchdog.camera_reolink_jardin INFO : Terminating the existing ffmpeg process...
2025-04-18 14:24:28.035448580 [2025-04-18 16:24:28] watchdog.camera_reolink_jardin INFO : Waiting for ffmpeg to exit gracefully...
2025-04-18 14:24:28.038470531 [2025-04-18 16:24:28] frigate.video ERROR : camera_reolink_jardin: Unable to read frames from ffmpeg process.
2025-04-18 14:24:28.038481302 [2025-04-18 16:24:28] frigate.video ERROR : camera_reolink_jardin: ffmpeg process is not running. exiting capture thread...
2025-04-18 14:24:38.047284698 [2025-04-18 16:24:38] watchdog.camera_reolink_jardin ERROR : Ffmpeg process crashed unexpectedly for camera_reolink_jardin.
2025-04-18 14:24:38.047300238 [2025-04-18 16:24:38] watchdog.camera_reolink_jardin ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2025-04-18 14:24:38.047478660 [2025-04-18 16:24:38] ffmpeg.camera_reolink_jardin.detect ERROR : [rtsp @ 0x55c6f7e56f40] method DESCRIBE failed: 404 Not Found
2025-04-18 14:24:38.047480663 [2025-04-18 16:24:38] ffmpeg.camera_reolink_jardin.detect ERROR : [in#0 @ 0x55c6f7e56bc0] Error opening input: Server returned 404 Not Found
2025-04-18 14:24:38.047481856 [2025-04-18 16:24:38] ffmpeg.camera_reolink_jardin.detect ERROR : Error opening input file rtsp://127.0.0.1:8554/your_reolink_camera_sub.
2025-04-18 14:24:38.047482747 [2025-04-18 16:24:38] ffmpeg.camera_reolink_jardin.detect ERROR : Error opening input files: Server returned 404 Not Found
2025-04-18 14:24:38.053989564 [2025-04-18 16:24:38] watchdog.camera_reolink_jardin ERROR : No new recording segments were created for camera_reolink_jardin in the last 120s. restarting the ffmpeg record process...
2025-04-18 14:24:38.054069657 [2025-04-18 16:24:38] watchdog.camera_reolink_jardin INFO : Terminating the existing ffmpeg process...
2025-04-18 14:24:38.054641862 [2025-04-18 16:24:38] watchdog.camera_reolink_jardin INFO : Waiting for ffmpeg to exit gracefully...
2025-04-18 14:24:38.060377733 [2025-04-18 16:24:38] frigate.video ERROR : camera_reolink_jardin: Unable to read frames from ffmpeg process.
2025-04-18 14:24:38.060617992 [2025-04-18 16:24:38] frigate.video ERROR : camera_reolink_jardin: ffmpeg process is not running. exiting capture thread...
2025-04-18 14:24:48.065704649 [2025-04-18 16:24:48] watchdog.camera_reolink_jardin ERROR : Ffmpeg process crashed unexpectedly for camera_reolink_jardin.
2025-04-18 14:24:48.065707665 [2025-04-18 16:24:48] watchdog.camera_reolink_jardin ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
2025-04-18 14:24:48.070843281 [2025-04-18 16:24:48] ffmpeg.camera_reolink_jardin.detect ERROR : [rtsp @ 0x559a798edf40] method DESCRIBE failed: 404 Not Found
2025-04-18 14:24:48.070899059 [2025-04-18 16:24:48] ffmpeg.camera_reolink_jardin.detect ERROR : [in#0 @ 0x559a798edbc0] Error opening input: Server returned 404 Not Found
2025-04-18 14:24:48.070900642 [2025-04-18 16:24:48] ffmpeg.camera_reolink_jardin.detect ERROR : Error opening input file rtsp://127.0.0.1:8554/your_reolink_camera_sub.
2025-04-18 14:24:48.071012315 [2025-04-18 16:24:48] ffmpeg.camera_reolink_jardin.detect ERROR : Error opening input files: Server returned 404 Not Found
2025-04-18 14:24:48.078139466 [2025-04-18 16:24:48] watchdog.camera_reolink_jardin ERROR : No new recording segments were created for camera_reolink_jardin in the last 120s. restarting the ffmpeg record process...
2025-04-18 14:24:48.078152641 [2025-04-18 16:24:48] watchdog.camera_reolink_jardin INFO : Terminating the existing ffmpeg process...
2025-04-18 14:24:48.078228477 [2025-04-18 16:24:48] watchdog.camera_reolink_jardin INFO : Waiting for ffmpeg to exit gracefully...
2025-04-18 14:24:48.084404014 [2025-04-18 16:24:48] frigate.video ERROR : camera_reolink_jardin: Unable to read frames from ffmpeg process.
2025-04-18 14:24:48.084425605 [2025-04-18 16:24:48] frigate.video ERROR : camera_reolink_jardin: ffmpeg process is not running. exiting capture thread...
