FRITZ!Box compent fails after FRITZ!OS 7.11
Today I’ve updated my FRITZ!Box to OS 7.11 and now I’m unable to setup the relative component.
Nothing is changed on my HASS config.
The following is my log:
2019-06-18 15:56:07 ERROR (MainThread) [homeassistant.setup] Error during setup of component fritzbox
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 387, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 383, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.7/http/client.py", line 1321, in getresponse
    response.begin()
  File "/usr/local/lib/python3.7/http/client.py", line 296, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.7/http/client.py", line 257, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/local/lib/python3.7/socket.py", line 589, in readinto
    return self._sock.recv_into(b)
socket.timeout: timed out
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 641, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 368, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py", line 686, in reraise
    raise value
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 603, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 389, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 307, in _raise_timeout
    raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.1.1', port=80): Read timed out. (read timeout=10)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 156, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/fritzbox/__init__.py", line 54, in setup
    fritzbox.login()
  File "/usr/local/lib/python3.7/site-packages/pyfritzhome/fritzhome.py", line 111, in login
    (sid, challenge) = self._login_request()
  File "/usr/local/lib/python3.7/site-packages/pyfritzhome/fritzhome.py", line 62, in _login_request
    plain = self._request(url, params)
  File "/usr/local/lib/python3.7/site-packages/pyfritzhome/fritzhome.py", line 49, in _request
    rsp = self._session.get(url, params=params, timeout=timeout)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 546, in get
    return self.request('GET', url, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.1.1', port=80): Read timed out. (read timeout=10)
2019-06-18 15:56:12 ERROR (SyncWorker_0) [homeassistant.components.fritzdect.switch] Login to Fritz!Box failed
Maybe is needed to open a github issue? Anyone with the same problem?
