fribse
(Kenneths Teknik)
September 15, 2019, 6:47pm
1
Hi all
I have the fritz.box integrated here, but for some reason it shows negative values.
I can’t figure out the pattern, because it’s not because it’s positive numbers in one direction, and negative in the other, but it shows both positive and negative values for each direction.
Does it show that in UPnP integration?
hsepm
(Holger)
September 16, 2019, 7:32am
3
For me, this is happening during the daily forced disconnect of the ISP.
Mitigation:
download:
value_template: >
{% set rate = state_attr('sensor.fritzbox', 'transmission_rate_down')|int(0) %}
{% if rate < 0 %}
0.00
{% else %}
{{ ((rate | float * 1 / 125000 )) | round(2) }}
{% endif %}
friendly_name: 'Download'
unit_of_measurement: 'Mbit/s'
upload:
value_template: >
{% set rate = state_attr('sensor.fritzbox', 'transmission_rate_up')|int(0) %}
{% if rate < 0 %}
0.00
{% else %}
{% endif %}
friendly_name: 'Upload'
fribse
(Kenneths Teknik)
September 17, 2019, 8:01am
4
@DavidFW1960 Yes, it’s the UPnP integration.
fritzbox:
devices:
- host: IP
username: !secret fritz_user
password: !secret fritz_pass
The sensors are called:
sensor.fritz_box_7560_kbyte_sec_received
sensor.fritz_box_7560_kbyte_sec_sent
@hsepm I don’t think I have a daily disconnect on my fiber connection, I should get a mail every time it is disconnected and get’s an IP.
pitleh
November 24, 2020, 7:32am
5
Hi Holger,
I have the same problem, could you please tell me where to put that snippet of code?
Thanks in advance
pitleh
November 24, 2020, 8:07am
6
… never mind, I figured it out.
Sorry, I am new to the project but already loving it. Yaml is not yet my friend
teasy
January 26, 2021, 5:33pm
7
Hey,
I’m new to this and have an identical issue.
How did you apply your mitigation script?
fribse
(Kenneths Teknik)
January 26, 2021, 8:10pm
8
What @hsepm is showing is two new sensors, that corrects the readout from the router integration.
Or you could use the range filter, which does the same and no need for templates.
fribse
(Kenneths Teknik)
January 27, 2021, 7:36am
10
Help out the guy, instead of just posting half claims please, what you suggest is also new sensors, but give him some examples.
ok, so the native sensors of the fritzbox are called something like:
sensor.fritzbox_kib_s_received
sensor.fritzbox_kib_s_sent
To filter out negative values, you have to create a template-Sensor based on this native sensor:
- platform: filter
entity_id: sensor.fritzbox_kib_s_received
filters:
- filter: range
upper_bound: 60000.0
lower_bound: 0.0
- platform: filter
entity_id: sensor.fritzbox_kib_s_sent
filters:
- filter: range
upper_bound: 10000.0
lower_bound: 0.0
As mentioned in the documentation https://www.home-assistant.io/integrations/filter/
fhe range-filter will replace any value out of the defined range with the value of the corresponding boundary.
