Fritzbox tools UI problems
Where I can find username and password to add the Fritzbox tools integration?
I tried admin as username and as password the one I use to enter in the router but I get unknown error. More, where to find the host address of the router?
Log into the FB dashboard, then go to system > Fritz!box Users. You should see a user fritz#### where the hashes are 4 digits. That’s your admin username, to go along with your admin password.
You can find the IP address of the router in the Home Network > Network screen - the Fritzbox should be listed at the top of the list. You can also try 192.168.178.1, which is the default factory IP address of the FB.
