From a general Nerd to an ESPHome Nerd, what does this mean in real words
So, not quite sure what this is telling me and If I could improve by doing something here.
Lots of words and I don’t understand the context I guess…
I’ve seen this on all the builds I think, so it’s in the package, so what to change if anything.
Build Excerpt:
INFO ESPHome 2026.9.0
INFO Reading configuration /config/esphome/stairway.yaml…
WARNING ‘ota’ password wastes significant flash and RAM (about 3.5 KB and 60 bytes plus the password on the heap): the device already offers encryption with the ‘api’ encryption key, which authenticates any uploader that takes it, and a password only matters for uploaders without encryption support; remove ‘password’ and add ‘encryption’ under ‘ota’ so uploads use the key and encryption is required
INFO Generating C++ source…
Top of the esphome yaml…
substitutions:
  friendly_name: Stair Light
  board: esp01_1m
packages:
  device_base: !include /config/esphome/packages/sg_8266_base.yaml
esphome:
  area: upstairs
  name_add_mac_suffix: false
  on_boot:
    priority: 600
    then:
      - lambda: |-
          id(button1_enabled) = true;
wifi:
  manual_ip:
    gateway: !secret chaloupkaabode_gateway
    subnet: !secret chaloupkaabode_subnet
    static_ip: !secret stairway_IP
    dns1: !secret chaloupkaabode_gateway
status_led:  And it continues with the gpio stuff...
PACKAGE:
# The stuff I need in all my espHome devices.
# I reserve the right to overwrite any at any time.
# Path to file: esphome/packages/sg_base.yaml
Top of the device config YAML
substitutions:
  friendly_name: Another Brick in the Wall
  frame_type: esp-idf
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: true
esp8266:
  framework:
    version: recommended
  board:  ${board}
  # Enable logging
logger:
  # Enable Home Assistant API
api:
  encryption:
    key: !secret chaloupkaabode_encrypt
ota:
  - platform: esphome
    password: !secret chaloupkaabode_otapw
wifi:
  phy_mode: 11G
  networks:
    - id: main_house_ap
      ssid: !secret chaloupkaabode_wifi_ssid
      password: !secret chaloupkaabode_wifi_password
    - id: second_house_ap
      ssid: !secret chaloupkaabode_wifi2_ssid
  ap:
    ssid: "${name} Fallback"
    password: !secret ap_password
web_server:
  port: 80
time:
  # Sync time with HA
  - platform: homeassistant
    timezone: "America/Chicago"
    on_time_sync:
      - component.update: sensor_uptime_timestamp
text_sensor:
  # IP Address & SSID
  - platform: wifi_info
    ip_address:
      icon: mdi:wifi
      entity_category: diagnostic
# Sensors with general information.
  # Uptime sensor (internal only).
  - platform: uptime
  # Uptime timestamp
    device_class: "timestamp"
    accuracy_decimals: 0
    update_interval: never
    lambda: |-
      static float timestamp = (
        id(time_homeassistant).utcnow().timestamp - id(sensor_uptime).state
      return timestamp;
  # WiFi Signal sensor.
  - platform: wifi_signal
    icon: mdi:wifi-strength-2
    update_interval: 60s
button:
  - platform: safe_mode
    name: "Safe Mode Boot ${name} ${friendly_name}"
  - platform: restart
    name: "Restart ${name} ${friendly_name}"
Instead of a separate password for OTA, the recommended method these days (if you’re already using encryption) is to use the API encryption key:
ota:
  - platform: esphome
    encryption:
So trying to sift thru that, I basically
api:
  encryption:
ota:
  - platform: esphome
to
api:
  encryption:
ota:
  - platform: esphome
    encryption:
following ESPHome OTA Updates - ESPHome - Smart Home Made Simple.
Yeah, I recognised several of the keywords, but it didn’t make much sense to me either :frowning: It’s just the developers with their terse descriptions understandable only to other developers, as a way of forcing mere users to come up to their level. Like reading the super brief and cryptic descriptions in the so called “release notes”.
However I followed the code recommendations and after fixing the errors from three attempts to compile, my project is still working.
What? You mean “bump qxworxy to v1.2.9.8” doesn’t tell you exactly what changed, and how it might impact your installation?
