From Alexa to Home Assistant: A Zero-Disruption Migration Strategy
Migrating a large, established smart home to Home Assistant can feel overwhelming—especially when everything already works.
I knew two things going in:
  • I wouldn’t be able to do it in a weekend
  • I couldn’t afford to break the home while learning
So I built my migration around a single rule:
No disruptions to the current home.
What I didn’t realize at the start was this:
The key wasn’t replacing Alexa—it was redefining its role.
Instead of being the orchestrator, Alexa became the voice interface.
Home Assistant became the brain.
Using the Home Assistant Skill for Alexa as a bridge, I migrated my entire system one integration at a time—without disrupting daily life.
This post walks through exactly how I did it.
The Architecture Shift: From Orchestrator to Voice Interface
Before the migration, my architecture looked like this:
Alexa → Skills → Devices
After the migration:
Alexa → Home Assistant → Integrations → Devices
The shift was simple, but powerful:
  • Alexa no longer controlled devices directly
  • Home Assistant became the single orchestration layer
  • Alexa simply passed voice commands into Home Assistant
This was all made possible by the Home Assistant Skill for Alexa, which acted as a bridge between the two worlds.
What Triggered the Move
Like many migrations, mine started with a breaking change.
I was using the Amazon IFTTT skill to integrate with my access control system (OpenPath), which exposed APIs that allowed HTTP POST commands to unlock both a front gate and front door.
In December–January 2024, Amazon deprecated that skill.
That left me with few options—until I discovered Home Assistant could issue those same API calls directly.
That was the starting point.
From there, I went deep into the Home Assistant community—especially YouTube—and credit goes in particular to the Everything Smart Home channel. Videos like 15 Home Assistant Tips You Must Do and Keep Your Home Assistant Running Smoothly With This were instrumental in my early setup.
The Migration Strategy: The Bridge Model
I approached this as a bridge migration, not a cutover.
Instead of replacing Alexa all at once, I:
  1. Moved integrations into Home Assistant
  2. Validated stability and functionality
  3. Removed the Alexa skill
  4. Exposed the devices and automations back to Alexa via Home Assistant
This allowed Alexa to continue working exactly as before—while gradually shifting control behind the scenes.
My Planning Approach
I created a comprehensive To-Do list that served as both a roadmap and a pacing tool.
It started with foundational setup:
  • Initial Home Assistant configuration
  • Core system optimizations
  • Voice activation
  • External access (Nabu Casa)
Then moved into integrations:
  • OpenPath API calls
  • Insteon
  • Reolink
  • Hunter Douglas
  • Ring
  • Sonos
  • ADT
  • Orbit
  • Tesla
  • Miele
  • Smart Meter Texas
  • Presence detection (Apple devices)
  • Text-to-Speech
  • ChatGPT integration
  • Microsoft 365 integrations
And finally:
  • Migration of Alexa routines
  • Voice assistant replacement strategy
  • Audio output routing (Sonos-based responses)
This structure allowed me to spread the learning curve over time and adapt as I discovered new capabilities. I also had a huge disruption when I shifted my entire network, cameras and access control over to Unifi - so there was a significant adjustment to the original plan.
The Repeatable Process (The Most Important Part)
For each integration, I followed the same process:
1. Install the integration in Home Assistant
2. Discover and validate devices
3. Assign devices to areas (rooms)
4. Apply clear naming for voice control
5. Recreate Alexa routines as Home Assistant automations
6. Test thoroughly
7. Remove the Alexa routine
8. Remove the Alexa skill
9. Expose entities back to Alexa via Home Assistant
10. Validate voice control end-to-end
This method ensured:
  • No duplicate devices
  • No broken automations
  • No confusion for Alexa
And most importantly—no disruption to the household.
What I Learned (and Didn’t Expect)
My original assumption was that Home Assistant would simply replicate what Alexa skills could do.
That was completely wrong.
A perfect example: Hunter Douglas shades
In Alexa:
  • The skill only exposed scenes
  • I had 60+ routines just to manage them
In Home Assistant:
  • Each shade was individually controllable
  • I could set precise positions (“Set Den Shade to 60%”)
  • I could build automations based on:
    • Sunrise offsets
    • Weather conditions
    • Real-time light levels in the room
Those 60+ routines disappeared—and were replaced with a more intelligent, adaptive system.
The Human Factor (Don’t Skip This)
The technical side of this migration was straightforward compared to the human side.
When you change a smart home, you are changing behavior:
  • Voice commands change
  • Device names change
  • Expectations change
I found it critical to:
  • Introduce new terminology before changes happen
  • Reinforce changes as they occur
  • Keep experiences predictable and consistent
Otherwise, you risk what I’ll call smart home rejection:
“This is too complicated”
“I can’t remember how to use this”
In my case, the biggest remaining challenge is the wake word.
We spent five years saying “Alexa.” Replacing that habit has proven harder than any integration.
We’re currently testing alternatives—but this reinforces an important lesson:
A smart home isn’t successful unless everyone in the home can use it effortlessly.
Where I Am Now
Most of the migration was completed within four months.
The final phase has been:
  • Removing Alexa hardware
  • Replacing it with Home Assistant Voice Preview Edition devices
  • Expand the Voice capabilities beyond just smart home control into general Q&A functions with OpenAI
  • Building dashboards where Alexa Shows once existed
The system is now fully orchestrated by Home Assistant, with voice as just one interface layer.
Key Takeaways
If you’re considering a similar migration, here’s what matters most:
  • Don’t migrate everything at once
  • Use Alexa as a bridge, not a dependency
  • Move integrations before automations
  • Test thoroughly before removing the old path
  • Optimize after migration—not before
  • Design for the people in the home, not just the technology
And most importantly:
A calm, reliable home is always better than a clever one.
If you're on this journey, take your time.
You don’t need a weekend—you need a plan.
And if you follow a zero-disruption approach, your home will never feel “in transition”—it will simply keep getting better.
