Fronius Solar, BESS, EV Charging
This is the back-end services for my Home Energy Management dashboard.
I have been cleaning up automations that have sprawled over the last 5-years. One of these clean-up was replacing my old and, simple solar inverter with a shiny new one.
The new solar system is a substantial improvement on the old one. As soon as it was added, I realised some gaps.
What are the questions this is trying to answer
  • How can I control my renewable assets without another vendor app or two?
  • How to save money? (Set and Forget)
  • What did my stuff do? (Notes and detailed logs)
  • What is my stuff doing now (Control)
Here is the critical hardware used:
  • Fronius GEN24 (Inverter)
  • Fronius Smart IP Meter
  • Fronius Reserva Battery Energy Storage Solution (BESS)
  • Fronius Wattpilot Flex (EV Charger)
Associated articles:
Here is what you will need to complete this setup:
  • Home assistant + HACS
  • Static IP address for inverter (or smart meter) and EV charger
  • Inverter will require the technician password or at least the technician to enable some settings for this to work (username + password)
  • EV charger will require the serial number and the default password
Step 1:
Add custom repo’s in HACS (http://homeassistant.local:8123/hacs/dashboard → 3 dots menu in top right → custom repositories)
https://github.com/callifo/fronius_modbus
https://github.com/mk-maddin/wattpilot-HA
Step 2.
Restart Home Assistant
Step 3.
Add integrations (http://homeassistant.local:8123/config/integrations/dashboard > +Add integration)
Fronius Modbus
Fronius Wattpilot
Step 4.
See what automations for your use case. For my personal use case, I am in Perth, Western Australia, using the Synergy time-of-use tariff. I have the following goals for my renewables investment:
  • Peak Shaving: Discharging stored battery power during expensive peak-demand hours to reduce commercial utility “demand charges”.
  • Energy Arbitrage: Charging the batteries when electricity is cheap (e.g., in the middle of the night) and discharging them when grid prices are high.
  • Renewable Integration: Storing excess energy generated by onsite solar panels for use when the sun isn’t shining.
  • Grid Services (VPP or Virtual Power Plant): Participating in demand response programs to stabilise the local utility grid and even generate revenue.
  • Grid Resilience (Blackout protection): Participating in demand response programs to stabilise the local utility grid and even generate revenue.
Here is some more information on this VERY loaded topic Rapid backup understanding UPS vs BESS technologies
Step 5.
Deploy appropriate automations
Energy Tariffs changer
alias: Energy Tariffs changer
description: >-
  This routine is for a 4-tier Time of Use (TOU) tariff from Synergy in Western
  Australia.
  Automation created by Benn, full documentation available on HA communities
  https://community.home-assistant.io/t/fronius-solar-bess-ev-charging/1025454
triggers:
  - at: input_datetime.tou_06_00_off_peak
    variables:
      tariff: Off Peak
    trigger: time
  - at: input_datetime.tou_09_00_super_off_peak
    variables:
      tariff: Super Off Peak
    trigger: time
  - at: input_datetime.tou_15_00_peak
    variables:
      tariff: Peak
    trigger: time
  - at: input_datetime.tou_21_00_off_peak
    variables:
      tariff: Off Peak
    trigger: time
  - at: input_datetime.tou_23_00_overnight
    variables:
      tariff: Overnight
    trigger: time
actions:
  - parallel:
      - target:
          entity_id: select.tou_em_channel_b_energy
          option: '{{ tariff }}'
        action: select.select_option
      - action: logbook.log
        metadata: {}
          domain: automation
          message: '#Automation told me to do it.'
      - choose:
          - conditions:
              - condition: state
                state:
                  - Peak
            sequence:
              - action: input_number.set_value
                metadata: {}
                  entity_id: input_number.energy_tiered_price_current
                  value: 0.5533
              - parallel:
                    metadata: {}
                      domain: Select
                      message: 'Energy tariff: set rate for "Peak"'
                      entity_id: sensor.main_line_em_channel_b_energy
                    metadata: {}
                      domain: Select
                      entity_id: input_datetime.tou_15_00_peak
                    metadata: {}
                      domain: Select
          - conditions:
              - condition: state
                state:
                  - Super Off Peak
            sequence:
                metadata: {}
                  value: 0.0885
              - parallel:
                    metadata: {}
                      domain: Select
                      message: 'Energy tariff: set rate for "Super Off Peak"'
                    metadata: {}
                      domain: Select
                      entity_id: input_datetime.tou_09_00_super_off_peak
                    metadata: {}
                      domain: Select
          - conditions:
              - condition: state
                state:
                  - Off Peak
            sequence:
                metadata: {}
                  value: 0.2434
              - parallel:
                    metadata: {}
                      domain: Select
                      message: 'Energy tariff: set rate for "Off Peak"'
                    metadata: {}
                      domain: Select
                      entity_id: input_datetime.tou_21_00_off_peak
                    metadata: {}
                      domain: Select
                      entity_id: input_datetime.tou_06_00_off_peak
                    metadata: {}
                      domain: Select
          - conditions:
              - condition: state
                state:
                  - Overnight
            sequence:
                metadata: {}
                  value: 0.2434
              - parallel:
                    metadata: {}
                      domain: Select
                      message: 'Energy tariff: set rate for "Overnight"'
                    metadata: {}
                      domain: Select
                      entity_id: input_datetime.tou_23_00_overnight
                    metadata: {}
                      domain: Select
mode: single
Renewables sub-routine: BESS discharge limit to actual max
alias: 'Renewables sub-routine: BESS discharge limit to actual max'
description: >-
  This routine overwrites some minor back-end errors with Fronius inverters on
  actual maximum charge/discharge. You can identify this in >2 mins from the
  "Fronius reserva battery datasheet".
triggers:
  - trigger: numeric_state
    entity_id:
      - number.reserva_discharge_limit
    for:
      hours: 0
      minutes: 0
      seconds: 15
    above: 6760
conditions: []
actions:
  - parallel:
      - action: number.set_value
        metadata: {}
          entity_id: number.reserva_discharge_limit
          value: '6760'
        metadata: {}
          message: 'Renewables sub-routine: BESS discharge limit to actual max'
          domain: Select
mode: single
Renewables sub-routine: BESS PV charge limit to actual max
alias: 'Renewables sub-routine: BESS PV charge limit to actual max'
description: >-
triggers:
    entity_id:
      - number.reserva_pv_charge_limit
    for:
      hours: 0
      minutes: 0
      seconds: 18
    above: 6760
conditions: []
actions:
  - parallel:
        metadata: {}
          entity_id: number.reserva_pv_charge_limit
          value: '6760'
        metadata: {}
          message: 'Renewables sub-routine: BESS PV charge limit to actual max'
          domain: Select
mode: single
Renewables routine, Energy Arbitrage: Cheap TOU (part 1/2) Solar-only
alias: 'Renewables routine, Energy Arbitrage: Cheap TOU (part 1/2) Solar-only'
description: >-
  This routine is to limit grid charge and enable solar charging of a BESS unit.
triggers:
  - trigger: state
    entity_id:
      - select.tou_em_channel_b_energy
    to:
      - Super Off Peak
    for:
      hours: 0
      minutes: 0
      seconds: 1
conditions: []
actions:
  - sequence:
      - sequence:
          - action: select.select_option
            metadata: {}
              entity_id: select.reserva_battery_api_mode
              option: Manual
            metadata: {}
              entity_id: select.reserva_storage_control_mode
              option: Charge from Grid
          - action: switch.turn_on
            metadata: {}
              entity_id: switch.reserva_charge_from_grid
            data: {}
            metadata: {}
              entity_id: switch.reserva_charge_from_ac
            data: {}
          - parallel:
                metadata: {}
                  message: 'Renewables routine: Cheap TOU part 1 of 2 Solar-only charge'
                  domain: Select
                metadata: {}
                  domain: Select
                metadata: {}
                  domain: Select
                metadata: {}
                  domain: Select
      - sequence:
            metadata: {}
              value: '0'
              entity_id: number.reserva_grid_charge_power
          - delay:
              hours: 0
              minutes: 0
              seconds: 15
              milliseconds: 0
            metadata: {}
              entity_id: number.reserva_target_feed_in
              value: '0'
          - delay:
              hours: 0
              minutes: 0
              seconds: 15
              milliseconds: 0
mode: single
Renewables routine, Energy Arbitrage: Cheap TOU (part 2/2) Solar + Grid
alias: 'Renewables routine, Energy Arbitrage: Cheap TOU (part 2/2) Solar + Grid'
description: |-
triggers:
  - trigger: state
    entity_id:
    to:
      - Super Off Peak
    for:
      hours: 3
      minutes: 0
      seconds: 1
conditions: []
actions:
  - sequence:
      - sequence:
            metadata: {}
              option: Manual
            metadata: {}
            metadata: {}
            data: {}
            metadata: {}
            data: {}
          - parallel:
                metadata: {}
                  message: 'Renewables routine: Cheap TOU part 2 of 2 Solar+grid'
                  domain: Select
                metadata: {}
                  domain: Select
                metadata: {}
                  domain: Select
                metadata: {}
                  domain: Select
      - sequence:
            metadata: {}
              value: '6700'
          - delay:
              hours: 0
              minutes: 0
              seconds: 15
              milliseconds: 0
            metadata: {}
              value: '0'
          - delay:
              hours: 0
              minutes: 0
              seconds: 15
              milliseconds: 0
mode: single
Renewables routine, Energy Arbitrage: Expensive TOU - Peak Shaving ignore the grid
alias: 'Renewables routine, Energy Arbitrage: Expensive TOU - Peak Shaving ignore the grid'
description: >-
  This routine is to maximise "Peak Shaving"
triggers:
  - trigger: state
    entity_id:
    to:
      - Peak
conditions: []
actions:
  - parallel:
        metadata: {}
          option: Auto
        metadata: {}
          option: PV Charge and Discharge Limit
        metadata: {}
        data: {}
      - sequence:
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
            metadata: {}
              value: '6760'
            metadata: {}
              value: '6760'
      - action: switch.turn_off
        metadata: {}
        data: {}
      - parallel:
            metadata: {}
              domain: Select
            metadata: {}
              domain: Select
            metadata: {}
              domain: Select
            metadata: {}
              domain: Select
mode: single
Renewables routine, Grid Resilience: Shoulder TOU - Boost your battery (part1/2)
alias: 'Renewables routine, Grid Resilience: Shoulder TOU - Boost your battery (part1/2)'
description: >-
  This routine is for "Grid Resilience". This is an alternative to a static
  "minimum state of charge"; this is a 2-part process.
  1. Start: Charge your battery during a fairly cheap after-hours time until the
  goal % is reached. ~35% (This automation)
  2. End: Resume discharging using standard device settings
triggers:
  - trigger: state
    entity_id:
      - Off Peak
    to:
      - Overnight
conditions: []
actions:
  - sequence:
        metadata: {}
          option: Manual
      - delay:
          hours: 0
          minutes: 0
          seconds: 30
          milliseconds: 0
      - sequence:
            metadata: {}
            data: {}
            metadata: {}
            data: {}
          - delay:
              hours: 0
              minutes: 0
              seconds: 30
              milliseconds: 0
          - sequence:
                metadata: {}
              - delay:
                  hours: 0
                  minutes: 0
                  seconds: 30
                  milliseconds: 0
              - sequence:
                    metadata: {}
                      value: '3000'
                    metadata: {}
                      value: '6760'
                    metadata: {}
                      value: '0'
                    metadata: {}
                      domain: automation
                      message: >-
                        modbus automation to enable grid #Automation told me to
                        do it.
                      entity_id: sensor.reserva_state_of_charge
                    metadata: {}
                      domain: automation
                      entity_id: sensor.reserva_grid_charging
                      message: >-
                        do it.
mode: single
Renewables routine, Grid Resilience: Shoulder TOU - Boost your battery (part2/2)
alias: >-
  (part2/2)
description: >-
  2. End: Resume discharging using standard device settings (This automation)
triggers:
    entity_id:
      - sensor.reserva_state_of_charge_2
    above: 35
conditions:
  - condition: select.is_option_selected
    options:
      behavior: any
      for: '00:00:00'
      option:
        - Overnight
actions:
  - parallel:
      - sequence:
            metadata: {}
              option: Auto
            metadata: {}
              message: >-
                battery (part2/2)
              domain: Select
      - sequence:
            metadata: {}
              option: Auto
            metadata: {}
              message: >-
                battery (part2/2)
              domain: Select
      - sequence:
            metadata: {}
            data: {}
            metadata: {}
              message: >-
                battery (part2/2)
              domain: Select
      - sequence:
            metadata: {}
            data: {}
            metadata: {}
              message: >-
                battery (part2/2)
              domain: Select
mode: single
