Front end not loading
I recently upgraded from 0.104.3 to 0.108.2. Now when I start HA, I get these errors:
2020-04-10 13:02:17 ERROR (SyncWorker_7) [homeassistant.util.package] Unable to install package home-assistant-frontend==20200407.2: Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: '/srv/homeassistant/lib/python3.7/site-packages/hass_frontend/__init__.py' Consider using the '--user' option or check the permissions. 2020-04-10 13:02:17 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Requirements for frontend not found: ['home-assistant-frontend==20200407.2']. 2020-04-10 13:02:18 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
Its not clear to me what is broken with my frontend so I can figure out how to correct. Anyone have any ideas?
Changed cat so bumping it
