Frontend development failing to do a first build
Hello
I’m trying to set up my development environment following this guide:
I’m running on a Ubuntu 17.10
I’ve forked the home-assistant-polymer repository and cloned it to my station,
I’ve installed nvm,
I’ve installed yarn,
I did the nvm install and and nvm use as instructed,
when I’m trying to run the script script/bootstrap from the cloned directory and I get the following message:
ERROR: [Errno 2] No such file or directory: ‘install’.
Is there anything I’m doing wrong or anything I might be missing here?
Fixed.
Had to remove cmdtest before installing yarn.
