I’m about a month in to configuring HA. It’s doing a great job and I have high hopes for getting it to a point where it’s doing exactly what I want.
However, I’m having some kind of an issue that I can’t resolve. It’s similar to this issue: How to connect? Web interface, SSH and Samba not working!, but different enough that I thought it appropriate to post separately.
What’s happening is that the frontend will not load on 8 of 10 reboots (estimated), which has been very, very frustrating as I’ve been adding configurations and regularly updating, both requiring a full system restart. I always make sure the configuration is valid before rebooting. I’ve even rebuilt the entire system twice with the same results.
Here are the details:
Hardware: Raspberry Pi 3 Model B, CanaKit 5V 2.5A Raspberry Pi 3 B+ Power Supply / Adapter, Samsung 64GB 100MB/s (U3) MicroSDXC card, all within the SB Components Raspberry Pi 3 Model B+ Transparent Case.
Software: Hassio (config at bottom of post)
I use Chrome and get a “This site can’t be reached” error, specifically: ERR_CONNECTION_REFUSED. Changing browsers does not help. Same issue using http://hassio.local:8123 or http://192.168.1.100:8123 (I have my router configured to give it the same IP every time). The times the frontend does load, I never have any additional problems (shutting off, automations not working, frontend not loading w/o a subsequent restart, etc.).
I have HA setup with Samba for file sharing with my Windows 10 machine and it always works. I always truly connect to the network and never have issues accessing via file share - the issue is only with the frontend loading.
From the home-assistant log in the config folder, I do not get any errors aside from a setup delay and the occasional chromecast issue, both issues I see just as often when the frontend does load. Example from today:
2018-07-08 06:08:20 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-08 06:08:53 ERROR (SyncWorker_2) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
Also worth noting, I have my system connected via Ethernet to a satellite of my Orbi mesh network system (1 main router, 2 satellites in total) which works flawlessly with every other device at home.
I have rebuilt the entire system twice and am still encountering the same problem. Any thoughts? Config below FWIW (private details swapped with xxxxx), although this issue appears no matter what I have going on in there.
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: xxxxx
longitude: xxxxx
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: xxxxx
# metric for Metric, imperial for Imperial
unit_system: imperial
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: xxxxx
# Customization file
customize: !include customize.yaml
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
# api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
updater:
# include_used_components: true
# Discover some devices automatically
#discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
#conversation:
# Enables support for tracking state changes over time
#history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Text to speech
tts:
- platform: google
# Cloud
cloud:
# Z-Wave
zwave:
usb_path: /dev/ttyACM0
# Includes
group: !include groups.yaml
script: !include scripts.yaml
# Google Cast
cast:
# Hue Bridges
hue:
bridges:
- host: 192.168.1.101
allow_unreachable: true
# Insteon Hub (local)
insteon_local:
host: 192.168.1.102
username: xxxxx
password: xxxxx
timeout: 10
port: 25105
# Orbi Mesh Network
# Google Maps Location Sharing
device_tracker:
- platform: netgear
host: 192.168.1.1
username: admin
port: 80
password: xxxxx
- platform: google_maps
username: xxxxx
password: xxxxx
# IFTTT Integration (xxxxx)
ifttt:
key: xxxxx
# Pushover Notification (xxxxx)
notify:
- name: pushover
platform: pushover
api_key: xxxxx
user_key: xxxxx
# Darksky Weather (xxxxx)
- platform: darksky
api_key: xxxxx
monitored_conditions:
- summary
- temperature
- apparent_temperature
- ozone
- uv_index
# Circadian Light Sensor
sensors:
length_of_day_factor:
friendly_name: 'length of day factor for circadian light calculation'
value_template: >
{% if is_state('sun.sun' , 'above_horizon') %}
{% set daylength = ((as_timestamp(states.sun.sun.attributes.next_setting) - as_timestamp(states.sun.sun.attributes.next_rising)) / 3600) + 24 %}
{{ (daylength*-0.0063616)+0.11131 }}
{% endif %}
sensors:
farbtemp:
friendly_name: 'circadian light - color temperature'
unit_of_measurement: 'mired'
value_template: >
{{ ((states.sensor.length_of_day_factor.state | round (5))*((states.sun.sun.attributes.azimuth)-180)**2 + 175) | int }}
{% elif (as_timestamp(states.sun.sun.attributes.next_dusk)) - (as_timestamp(states.sun.sun.attributes.next_setting)) < 0 or (as_timestamp(states.sun.sun.attributes.next_rising)) - (as_timestamp(states.sun.sun.attributes.next_dawn)) < 0 %}
350
{% else %}
390
{% endif %}
# Tracking zones
zone:
- name: School
latitude: xxxxx
longitude: xxxxx
radius: 175
icon: mdi:school
- name: Home
latitude: xxxxx
longitude: xxxxx
radius: 40
icon: mdi:home
