Fujitsu AC (heat pump) integration via ESPHome [ESP32]
Are you able to connect thought CNC01 socket?
Is it 4pin or 5pin socket?
I have CNC01 5pin and i can’t find pinout.
Thanks Nathan,
Just placed an order…will you send a link for instructions and 3d model for the enclosure.
Just wondering what people do to control this from outside of your LAN. Would be good to turn the unit on when nobody home and its been a hot day.
If you shoot Nathan a message with your email he can send you the files. They were stl files. Alternatively, I just used a jiffy box from jaycar.
I assume most people will host a vpn to access it from outside their lan. Tailscale is probably the easiest and free as it gets around most of the complicated networking. Home assistant has paid cloud support or you can host your own wireguard vpn.
