Fujitsu anywAiR zones in Apple Home via Home Assistant GreeN
Before purchasing a Home Assistant Green, I would like to confirm compatibility with my Fujitsu anywAiR ducted air-conditioning system.
My anywAiR system has multiple zones, including temperature-controlled zones with wireless temperature sensors.
If I connect the Fujitsu anywAiR integration to Home Assistant Green and then use the HomeKit Bridge integration, will each temperature-controlled zone appear as a separate climate/thermostat accessory in the Apple Home app?
I would like to assign each zone to its corresponding room in Apple Home (for example, Master Bedroom, Family Room, Leisure Room, etc.) and control each zone individually.
I would also like to confirm whether Home Assistant Green alone is sufficient for this setup, without requiring an additional Zigbee/Thread dongle or other hardware.
