The last thing I did last night was installing the latest update 0.43.2 and I was using under 40% of my 16gb SD card. When I woke up this morning the SD card was full and the home assistant folder are 15,64GB, but I can’t find what it is that takes so much space when i am browsering the folder.
This looks like the Samsung TV module. Disable discovery and if you have the samsung tv component enabled - disable that as well, restart hass and see what happens. You can safely delete both files. They will be recreated when needed.
Needless to say this wears out your SD card, so it might be wise to set up /var/log to be in tmpfs, you can find instructions how to do that here:
Yes I had the Samsung TV modul but I never used it. I have now disabled then both as you recommended. The files are deleted and the rPi are restarted. I will get back with the result in a while
I will take a look at the guide for the SD card, thanks @kirichkov
