SD card failure…attempted to restore from full snapshot.
Restoring a snapshot and having difficulty restoring Maria DB and other addons. Supervisor logs have entry
20-06-01 17:35:47 ERROR (MainThread) [supervisor.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
Initially Maria DB was not started, I had to uninstall and reinstall and modify config.yaml. After getting that working on subsequent restarts sometimes webui wont work.
ssh always works as does SAMBA.
Can someone help me to restore years of configuration?
When I restored mine, MariaDB caused problems. With that, it wouldn’t work and a bunch of other addons didn’t get restored and neither did my config.
When I started from scratch and re-did it without MariaDB, everything worked properly … it took me around 30-45 minutes to restore, but realistically, that number will be different for all of us depending on hardware and our configs.
Then, I re-installed the addon manually and it worked. I was just missing the historical data, which I’m not too concerned about.
For me, I deleted the VM and started completely over (I don’t like to leave failure remnants floating around). Uninstalling MariaDB add-on and then re-restoring your data might be worth a shot though (definitely quicker).
If you have an extra SD card, maybe start prepping it while you’re restoring, in case you want to try that route if the re-restore doesn’t work.
