Fully Kiosk Browser 2022.9 Integration Unknown Error Occurred
Not sure what I’m doing wrong. I have updated to 2022.9.2. When trying to use the new Fully Kiosk Browser integration from the UI, I input the IP address and the password I setup for Remote Access to my fully licensed Fully Kiosk Browser running on an Amazon Fire tablet. I can access the Web UI of the kiosk via Chrome/Edge with no issues. But when I try to setup this integration with the same creds, I receive the error in the screenshot below:
I’ve tried rebooting my host system with the same results. Anyone else experiencing this issue? I looked in the forums, but didn’t find anything recent that pertains to this new integration, only entries for the HACS version.
Error Log:
Logger: aiohttp.server
Source: components/fully_kiosk/config_flow.py:54
First occurred: 11:14:47 AM (2 occurrences)
Last logged: 11:15:10 AM
Error handling request
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 178, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
    result = await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 280, in async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/fully_kiosk/config_flow.py", line 54, in async_step_user
    data=user_input | {CONF_MAC: format_mac(device_info["Mac"])},
KeyError: 'Mac'
Have you set this right?:
Yes, these are my settings:
Do i need Enable File Management on Remote Admin to be turned on? The integration documentation doesn’t specify what all needs turned on.
UPDATE: I enabled that setting, but still no go on setting up the integration.
File management should not have to be necessary.
I’m afraid, that is all, I can say right now. Here it works fine, but I have no further experience with it, have it up for 2 days now, did not play with it…
I am having the same issue, “Unknown Error Occurred”. I found an old post from the HACS integration stating that the special characters need to be percent-encoded for the API to handle it. So, I removed my special characters from my passwords, but it still does not work. I have three Fully Kiosk Plus licenses. Same error on all three instances.
Yeah, I changed mine to a 4 digit pin with the same results. I’d also like to mention that the HASS update notes state that HASS will auto-detect your FKB instances, but mine are not being detected. So I’m trying to manually add them through the Integration UI.
Since the last updat I lost my connection with Fully Kiosk. Is ther e anyone who have solve this problem?
Try the custom integration. That works for me. image
This does not solve the problem for me. I still get the same error, trying to connect.
I’m seeing this as well, double checked all my settings. Keep getting unexpected error.
Replying minutes later as I was able to solve this. The solutions above didn’t work. The integration fields are expecting the IP without the protocol or port.
So format like this:
192.168.xx.xx
And don’t do either of these:
http://192.168.xx.xx
192.168.xx.xx:2323
I encountered this error today after moving from the old HACS integration to the new one.
I deleted the old Fully Assistant integration and removed from HACS, then re-added the official one. Boom, error!
Kept happening…
Restart of HA solved it. So, make sure you restart HA before attempting to re-add the integration.
Any progress on this? I appreciate all the hard work so far and I’m excited to try this integration! here’s the errors it logs:
2025-04-04 21:55:09.011 ERROR (MainThread) [aiohttp.server] Error handling request from 192.168.1.170
  File "/usr/local/lib/python3.13/site-packages/aiohttp/resolver.py", line 106, in resolve
    resp = await self._resolver.getaddrinfo(
    ...<5 lines>...
aiodns.error.DNSError: (1, 'DNS server returned answer with no data')
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1351, in _create_direct_connection
    hosts = await self._resolve_host(host, port, traces=traces)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 995, in _resolve_host
    return await asyncio.shield(resolved_host_task)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1026, in _resolve_host_with_throttle
    addrs = await self._resolver.resolve(host, port, family=self._family)
  File "/usr/local/lib/python3.13/site-packages/aiohttp_asyncmdnsresolver/_impl.py", line 140, in resolve
    return await super().resolve(host, port, family)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/resolver.py", line 115, in resolve
    raise OSError(None, msg) from exc
OSError: [Errno None] DNS server returned answer with no data
  File "/usr/src/homeassistant/homeassistant/components/fully_kiosk/config_flow.py", line 59, in _create_entry
    device_info = await fully.getDeviceInfo()
  File "/usr/local/lib/python3.13/site-packages/fullykiosk/__init__.py", line 33, in getDeviceInfo
    result = await self.sendCommand("deviceInfo")
  File "/usr/local/lib/python3.13/site-packages/fullykiosk/__init__.py", line 25, in sendCommand
    data = await self._rh.get(
        cmd=cmd, password=self._password, type="json", **kwargs
  File "/usr/local/lib/python3.13/site-packages/fullykiosk/__init__.py", line 163, in get
    async with self.session.get(**req_params) as response:
  File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 1425, in __aenter__
    self._resp: _RetType = await self._coro
  File "/usr/local/lib/python3.13/site-packages/aiohttp/client.py", line 703, in _request
    conn = await self._connector.connect(
        req, traces=traces, timeout=real_timeout
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 548, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1056, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/connector.py", line 1357, in _create_direct_connection
    raise ClientConnectorDNSError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorDNSError: Cannot connect to host front-door-panel-note20-ultra:2323 ssl:False [DNS server returned answer with no data]
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 232, in post
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 121, in post
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 340, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 387, in _async_configure
        flow, cur_step["step_id"], user_input
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 490, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/fully_kiosk/config_flow.py", line 140, in async_step_discovery_confirm
    result = await self._create_entry(self.host, user_input, errors)
  File "/usr/src/homeassistant/homeassistant/components/fully_kiosk/config_flow.py", line 67, in _create_entry
    description_placeholders["error_detail"] = str(error.args)
TypeError: 'NoneType' object does not support item assignment
