Fully Kiosk Browser
With quotes it won’t work, this is what I’m referring to:
Here Markdown Reference
Anyone tell me why my battery level works but my charging status does not? Reports unknown.
mqtt:
    - name: "FKB Tablet Battery Level"
      state_topic: "fully/deviceInfo/galaxytab10"
      unit_of_measurement: "%"
      device_class: battery
      value_template: "{{ value_json.batteryLevel }}"
  binary_sensor:
    - name: "FKB Tablet Charging Status"
      payload_on: "true"
      payload_off: "false"
      qos: 0
      device_class: battery_charging
      value_template: "{{ value_json.plugged }}"
Have also tried {{ value_json.IsPlugged }}
most likely it is “isPlugged”
first character small and second word starts with a capital, like “batteryLevel”
and you can find the right keywords on the fully website.
Thanks, but I actually tried that first. I copied the correct name from MQTT Explorer.
My guess would be that this is some weird Python value conversion. The values returned for plugged in the MQTT message are true/false values, not strings, and I am guessing that the value_template converts them to booleans before trying to compare the boolean with the strings defined in payload_on/payload_off?
the stick to that, and find out what else you have wrong :wink:
maybe a capital in the payload, or that you use a binary sensor, or qos, or the deviceclass.
but if its “isPlugged” in mqttexplorer at least you know that THAT is correct.
not python, but yaml is the one doing wierd conversions :wink:
I just started my HA journey which includes setting up a Fire Tablet w/Fully Kiosk as my control panel. This thread has been very helpful, thank you! I want to share some of my learnings and setup as well.
I noticed the beginning OP uses sensor/platform rest. This calls the Rest API for those sensors but if you also want some binary sensors you have to setup a binary_sensor/platform rest and thus it seems a second API call is required. I saw in the HA docs you can use the Restful rest platform (top level) and place all the sensors under one call. Here is my full setup with some special features like % memory free, statuses, app restart time, etc:
# Load Tablet Sensor Info via API Call
  - resource: !secret ha_tablet_rest
    scan_interval: 20
    binary_sensor:
      - name: Living Room Tablet Kiosk Mode
        unique_id: homtab_kiosk_mode
        value_template: '{{ value_json.kioskMode }}'
      - name: Living Room Tablet Plugged In
        unique_id: homtab_plugged_in
        value_template: '{{ value_json.isPlugged }}'
      - name: Living Room Tablet Screen Locked
        unique_id: homtab_screen_locked
        device_class: lock
        value_template: '{{ value_json.screenLocked }}'
      - name: Living Room Tablet Screen On
        unique_id: homtab_screen_on
        value_template: '{{ value_json.screenOn }}'
      - name: Living Room Tablet Screen Saver On
        unique_id: hometab_screen_saver_on
        value_template: '{{ value_json.isInScreensaver }}'
      - name: Living Room Tablet Kiosk Locked
        unique_id: hometab_kiosk_locked
        device_class: lock
        value_template: '{{ value_json.kioskLocked }}'
      - name: Living Room Tablet MQTT Connected
        unique_id: hometab_mqtt_connected
        device_class: connectivity
        value_template: '{{ value_json.mqttConnected }}'
      - name: Living Room Tablet Motion Detector
        unique_id: hometab_motion_detector
        value_template: '{{ value_json.motionDetectorStatus }}'
      - name: Living Room Tablet Current Tab
        unique_id: hometab_current_tab
        value_template: '{{ value_json.currentTabIndex }}'
      - name: Living Room Tablet Last App Start
        unique_id: hometab_last_app_start
        device_class: timestamp
        value_template: '{{strptime(value_json.lastAppStart+"-0500",
                                    "%m/%d/%y %I:%M:%S %p%z",
                                    "1/1/1900 00:00:00 AM")}}'
      - name: Living Room Tablet Wifi Signal Strength
        unique_id: hometab_wifi_signal_strength
        device_class: signal_strength
        value_template: '{{ value_json.wifiSignalLevel }}'
      - name: Living Room Tablet Battery Level
        unique_id: hometab_battery_level
        unit_of_measurement: '%'
        value_template: '{{ value_json.batteryLevel }}'
      - name: Living Room Tablet Battery Temperature
        unique_id: hometab_battery_temperature
        device_class: temperature
        unit_of_measurement: '°C'
        value_template: '{{ value_json.batteryTemperature }}'
      - name: Living Room Tablet Storage Free Space
        unique_id: hometab_storage_free_space
        json_attributes:
          - internalStorageFreeSpace
          - internalStorageTotalSpace
        value_template: '{{(value_json.internalStorageFreeSpace /
                            value_json.internalStorageTotalSpace *100)|round(1)}}'
      - name: Living Room Tablet RAM Free
        unique_id: hometab_ram_free
        json_attributes:
          - ramFreeMemory
          - ramTotalMemory
        value_template: '{{(value_json.ramFreeMemory /
                            value_json.ramTotalMemory * 100)|round(1) }}'
      - name: Living Room Tablet App Free Memory
        unique_id: hometab_app_free_memory
        json_attributes:
          - appFreeMemory
          - appTotalMemory
        value_template: '{{(value_json.appFreeMemory /
                            value_json.appTotalMemory * 100)|round(1) }}'
This is included via a config file entry of:
rest: !include rest.yaml
I have Fully Kiosk Plus which has built in MQTT which I turned on. I quickly noticed the kiosk was pushing device info messages just like the Rest API provides, but a push vs a pull. So I decided to investigate switching to MQTT. I am glad I did, a couple of cool things:
  • Seems a little easier to setup and manage (you can listen to MQTT topics to debug)
  • Push vs pull model based on changes/events
  • Really cool… I set an expire time for the MQTT connectivity sensor (mine is 60 seconds) so if there is no device info message sent in 60 seconds, then it shows the connection as unavailable. Soon as device is back online a message is sent and shown as available.
Here is the same set of sensors but setup via MQTT (some fields slightly changed):
# All MQTT Sensors
  binary_sensor:
    - name: HA Tablet Kiosk Mode
      unique_id: tab_kiosk_mode
      payload_on: true
      payload_off: false
      state_topic: living_room_tablet/deviceInfo
    - name: HA Tablet Plugged In
      unique_id: tab_plugged_in
      payload_on: true
      payload_off: false
    - name: HA Tablet Screen Locked
      unique_id: tab_screen_locked
      payload_on: true
      payload_off: false
      device_class: lock
    - name: HA Tablet Screen On
      unique_id: tab_screen_on
      payload_on: true
      payload_off: false
    - name: HA Tablet Screen Saver On
      unique_id: tab_screen_saver_on
      payload_on: true
      payload_off: false
    - name: HA Tablet Kiosk Locked
      unique_id: tab_kiosk_locked
      payload_on: true
      payload_off: false
      device_class: lock
    - name: HA Tablet MQTT Connected
      unique_id: tab_mqtt_connected
      payload_on: true
      payload_off: false
      expire_after: 60
    - name: HA Tablet Motion Detector
      unique_id: tab_motion_detector
    - name: HA Tablet Current Tab
      unique_id: tab_current_tab
      value_template: >
        {% if value_json.currentTabIndex == 0 %}
          Home
        {% elif value_json.currentTabIndex == 1 %}
          Camera
        {% elif value_json.currentTabIndex == 2 %}
          Temps
        {% else %}
        {% endif %}
    - name: HA Tablet Last App Start
      unique_id: etab_last_app_start
      value_template: '{{strptime(value_json.appStartTime+"-0500",
    - name: HA Tablet Wifi Signal Strength
      unique_id: tab_wifi_signal_strength
    - name: HA Tablet Battery Level
      unique_id: tab_battery_level
    - name: HA Tablet Battery Temperature
      unique_id: tab_battery_temperature
    - name: HA Tablet Storage Free Space
      unique_id: tab_storage_free_space
    - name: HA Tablet RAM Free
      unique_id: tab_ram_free
    - name: HA Tablet App Free Memory
Again pulled in via the config file:
mqtt: !include mqtt.yaml
Note: I converted the current tab index # to a label based on what tabs I have setup.
After trying both, I have removed the Rest version and sticking with MQTT.
I created this admin view dashboard for the tablet status:
Clicking on the camera card brings up a live feed of the camera - bonus!
Pretty fun integration.
New users only get one media item per post… so here is my Fully Kiosk MQTT settings:
Be sure to change the Device and Event topic to make them easier to see/use in HA.
I’m not sure if it’s what you’re looking for, but what about using fully kiosk kiosk integration instead of mqtt? It shows all these values in HA and you can alter some things (like lock, screensaver, load start url…)
EDIT: Cancel that. The below does not work as the JSON does not update for some reason.
I found a workaround here. Thanks @atomicpapa
mqtt:
    - name: FKB Tablet JSON
      unique_id: fkb_tablet_json
      json_attributes_topic: "fully/deviceInfo/galaxytab10"
Then strip the attributes from the new sensor.
    sensors:
      tablet_charging_status:
        friendly_name: Tablet Charging Status
        value_template: >-
          {% if is_state_attr('sensor.fkb_tablet_json', 'isPlugged', true) %} Yes {% else %} No {% endif %}
        icon_template: >-
          {% if is_state_attr('sensor.fkb_tablet_json', 'isPlugged', true) %} mdi:power-plug {% else %} mdi:power-plug-off {% endif %}
There may be a way to use json_attributes_template: to strip the actual charging state directly but I can’t figure that out.
Any way we can workaround that? It seems my workaround above does not update correctly so I do need this binary sensor somehow.
The attribute isPlugged does not change state in the sensor.fkb_tablet_json even though it does in the main MQTT path at fully/deviceInfo/galaxytab10
Fixed it! Found this here.
Simply remove the quote marks around the payload.
  binary_sensor:
    - name: FKB Tablet Charging Status
      unique_id: fkb_tablet_charging_status
      payload_on: true
      payload_off: false
      qos: 0
      value_template: "{{ value_json.isPlugged }}"
firetoolbox used and it goes to sleep when i tell it too and wakes up when i tell it too.
Thanks for everyones contributions to this. I have 6 tablets set up using Fully Kiosk Browser and it is great. I’ve configured a single switch in my conguration for turning on/off the tablet screen from HA which has worked great. However when I attempted to implement this for more than one tablet, I found it only worked for the 1st defined switch and none of the others. No errors etc but it just doesn’t work.
Is anyone able to advise what I’ve done wrong please?
switch:
  - platform: command_line
    switches:
      living_room_tab_screen:
        command_on: !secret living_room_tab_screen_on
        command_off: !secret living_room_tab_screen_off
        command_state: !secret living_room_tab_screen_state
        value_template: '{{ value == "on" }}'
        friendly_name: Living Room Tab Screen
      games_room_tab_screen:
        command_on: !secret games_room_tab_screen_on
        command_off: !secret games_room_tab_screen_off
        command_state: !secret games_room_tab_screen_state
        friendly_name: Games Room Tab Screen
hard to tell without knowing the command_on, command_off and command_state
Help - how to I do Webview Debugging in Fully Kiosk? I switch it on in settings - then what?
Something on my dashboard is intermittently crashing Fully and it’s driving me nuts trying to work out what it is.
Have you figured out how to do this? I had the same issue, so I updated the software to 1.49.1, that seemed to solve the issue but now I have a memory issue where the firetablet HD10 2021 memory usage drops to under 250 mg and becomes unstable. Restarting is tablet works only to have the same issue in 12 hrs.
Memory usage for FK is 1.5 GB.
I didn’t figure out how to use the debugging, but I did eventually find the issue with my dashboard. First changed the Fully URL to google.com - no crashes - so it was definitely something on my dashboard. Turns out it was the animated SVG weather icons causing the memory leak. I’ve reverted to static icons for the time being, but hoping I can eventually find a solution. Next thing on my list to try is installing an older version of Android Webview.
thanks for sharing.
Just curious, how you found out what card(s) was causing the issue? I’m now at this point because my memory leak is still happening :frowning:
