Hello. I was given a cheap CCTV camera.
When I connected it to the Home Assistant, it displays the video as it should. But when I connected it to Frigate, it displays the video very funny. How to make a normal display in Frigate?
you are setting the wrong resolution in
detect:
width:
height:
And, the ad is funny too.
I am pretty sure a 2.0MP lens pointing right and a 2.0MP lens pointing left is not 4.0MP.
Just add two or three more cheap lenses and you would have an AMAZING picture
It’s not about the number of cameras. ))) And in displaying information in Frigate.
P.S. I have a slightly different camera without a name, but very similar. So no advertising, I found photos on the Internet.
If the device combine the two pictures without too much overlap, then the result will be a 4MP device/camera.
The MP value is just referring to the number of pixels in the picture taken and does not take into account any other factors that might influence a pictures quality.
Having the two photo sensor behind each their own lens or having the two sensors behind the same lens or having own sensor that can cover the entire field does not really make a difference in relation to MP values.
Yeah. I had resolution in my mind. Duh
Hi can you give me full url stream this camera becouse i cant add camera 180 to home assistant.Please
detect:
width: 2560
height: 720
