I have my voice assistant on my galaxy watch 8 and it worked perfectly until it didn’t… It just crashes everytime after loading. I think that nothing has change in between. I have reinstalled the apps, cleared cache and restarted every device. Didn’t fix it…
I have the same issue.
On watch 7 is ok
On watch 8 crashes when it should listen command.
I tried to reset whole watch, remove it from HA, add again, same result.
Everything updated.
Same here. Working at Watch 7. Christmas gift Watch 8 for partner isnt working. It loads the display of Voice Assistant. Microphone symbole is pulsating. Chat GPT is poping up on top after that Assistant closes directly.
Press MIC button, HA Assist pops up and appears to start listening, then after 1.5 seconds there is small text at the top that reads “Home Assistant Cloud” as soon as that appears the app closes.
It appears to be triggered by the connection to Home Assistant Cloud being established.
The issue is repeatable. I have tried a factory reset on the Galaxy Watch 8 with no change in behaviour.
