Hi all,
i need your help how i can solve the following issue:
I have a Homematic-IP-ip MOD_TM Novoferm Garage component.
This is shown nice in HA as a cover.
The MOD_TM has also a ventilation state which i want to trigger via HA. This 3. Mode is not integrated in the cover(“component”)
So my idea was to write a own template in configuration.xml in order to trigger the ventilation state.
But the state ventilation is not avalable as a cover.
Do you have ideas how to sole this? Shoult i use a different template and if yes which on?
### HMIP MOD_TM Garagentor ###########
cover:
covers:
garagentor_links:
friendly_name: "GaragentorLinks"
value_template: "{{ is_state('sensor.XXXX_door_state', 'closed') }}"
open_cover:
service: homematic.set_device_value
address: "<HOMEMATICSERIALNUMBER>"
channel: 1
param: DOOR_COMMAND
value: 1
close_cover:
channel: 1
param: DOOR_COMMAND
value: 2
stop_cover:
channel: 1
param: DOOR_COMMAND
value: 3
vent_cover:
channel: 1
param: DOOR_COMMAND
value: 4
