Garage door opener - bypassing proprietary access [article]
I thought others might find this article interesting – about a hardware project called RATGDO, for Rage Against the Garage Door Opener, for non-proprietary access to garage door openers made by Chamberlain Group that use MyQ hubs.
https://www.nytimes.com/2025/12/04/technology/personaltech/why-one-man-is-fighting-for-our-right-to-control-our-garage-door-openers.html
Yes this is a well known solution. Do a search of the forum. This isn’t your project to share either so I have moved the post.
FWIW, when I tried searching the forum before posting, the search completion box did not trigger a hit on any of the keywords myq, ratgdo or chamberlain…
https://community.home-assistant.io/search?q=RATDGO
or Search results for 'ratgdo order:latest' - Home Assistant Community :stuck_out_tongue:
And that’s even 25 results with the misspelling! :joy:
Results are maxed out (50+) with Search results for 'RATGDO' - Home Assistant Community
To clarify, I was using this part of the UI, which returned no search results (when there is a match actual page hits appear at the bottom of the dropdown). I will try the other search methods in the future.
heh more related news @ Chamberlain’s new technology blocks aftermarket controllers from working with its garage door openers | The Verge from @ https://www.reddit.com/r/homeassistant/comments/1pfr5ks/
Put this in a search engine. Well perhaps one of them at a time or add other keywords. Many responses otherwise.
site:home-assistant.io myq ratgdo chamberlain
https://community.home-assistant.io/t/tips-on-searching-for-answers-duplicate-topics-in-the-forum/703275
