Hi there,
I’m setting up an MQTT Cover with two sensors and a button to create a Garage Door opener.
While HA triggers the opening and closing states when I use HA to control the Garage Door, I could not find a way to send the opening or closing commands over MQTT from my sensors to HA when I operate the Garage Door manually. This way, when I open the door manually the state in HA will be OPENING when I open the door from it’s closed position or CLOSING when I close the door from its opened position.
Is this possible?
This is my setup:
cover:
- platform: mqtt
friendly_name: Garage
state_topic: "stat/GarageDoor/DOOR"
command_topic: "cmnd/GarageDoor/power1"
availability_topic: "tele/GarageDoor/LWT"
payload_open: "ON"
payload_close: "ON"
payload_stop: "ON"
state_closed: "CLOSED"
state_opened: "OPENED"
payload_available: "Online"
payload_not_available: "Offline"
optimistic: false
retain: false
value_template: '{{ value }}'
homeassistant:
customize:
cover.GarageDoor:
device_class: garage
I’ve tried adding to the cover config:
state_closing: "CLOSING"
state_opening: "OPENING"
But that didn’t work unfortunately.
