Garage door status with Homematic IP sensor
I restart this One:
I just would like to use my Homematic IP sensor to check wether the Garage door is open or closed. But i cannot find in as usual in home assistant. Where do I now find this entitiy to use in the dashboard?
I use a CCU3 over XML API together with HA OS on a raspberry.
Which sensor do you use?
What I usually do is to get the serial number from CCU and search for the according entity in HA entities list. Then I give it a friendly name.
