Garage doors in Alarmo
I’m very new to HA and am in the process of moving everything over from Hubitat. I’ve been setting up Alarmo with my Zigbee binary sensors, and I want to also use my Meross garage door sensors, but they are categorized as covers rather than doors. Is there a way to make this work? Or is it possible to create a virtual binary sensor than I can trigger with an automation?
A few options you could look at.
  • Create a new Helper (Binary Sensor Template helper) to match your cover status. The template could be something like {{ states(‘cover.yourcoverentity’) }}. I just did this exact thing & i can include my garage door now.
  • You certainly could create a separate automation to do something like send notifications if the garage is opened while the alarm is armed.
  • Contact the developer of Alarmo to support covers directly.
    Cheers
    NIck
I’ve created the template and it looks as though it should work, but it’s state doesn’t change when I open or close my garage door.
Edit: I figured it out. Since my garage door entity (cover) was reporting open/closed, the binary sensor wasn’t interpreting the state, so I did this and it worked:
{{ is_state(‘cover.east_garage_door_msg100_main_channel’, ‘open’) }}
