Good evening everyone
I hope I am in the right place and not in the wrong section. If I am, please accept my apologies.
I have been using Home Assistant for several years now and have integrated almost everything in my house from the solar system to boiler monitoring and am very satisfied.
As I am now in the process of trying to renew or summarize old automations, I have now encountered a problem that I am now biting my teeth out.
The problem is that I have divided the lighting in my garden up to the garage into different groups so that everything up to and including the garage is not illuminated when I step outside the door.
So far I have solved this with individual automations and it has worked. Now that I have slowly lost track of all the automations, I wanted to redesign and summarize them.
But now I have the problem that the first part of the automation works and the first part of the outdoor lighting goes on as it should. But the other parts just don’t want to and I can’t find the error. I hope someone can help me here.
To start the automation I have a Zigbee motion detector and the rest is triggered via the people sensors of my Unifi cameras.
I also see in the automation that each trigger works or indicates but the light simply does not switch.
I have also triggered the lights manually with the labels and it works there. So it must be somewhere in the logic.
Here is the automation. Thank you already. Greetings from Switzerland
alias: Home Aussenlichtsteuerung
description: ""
triggers:
- type: occupied
device_id: 3f20ae222847465ac96ebe0e90939da5
entity_id: b4500e411f15eab603c8a2c1857b0a50
domain: binary_sensor
trigger: device
- type: occupied
device_id: e5dc9261210178d75a4d7e3851e4153d
entity_id: 7cfdaffd1dceb09c707b1ea4e5fc40b8
trigger: device
- type: turned_on
device_id: 9d1d2fbffdd9c7063a6443d6f668506d
entity_id: e2f79899bb132f74a719d88c9d95796b
trigger: device
- type: turned_on
device_id: f73cea3298336ec034d18b799be44fda
entity_id: cf32195722ce8d45189932751aa979fd
trigger: device
- type: occupied
device_id: 30662a923c784cad28b53b379f60da9e
entity_id: e113217dcfca91d01b62e1e5d0c2d27d
trigger: device
- type: not_occupied
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
enabled: true
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
enabled: true
- type: turned_off
entity_id: 8d4228af8488e5f7a0a6ce7a126baa3b
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
enabled: true
- type: turned_off
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
enabled: true
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
enabled: true
- type: turned_on
entity_id: 4047dea4d395ea07909f3fd8766d610c
trigger: device
- type: turned_on
device_id: 90efba41a64dd7d1833b3b2c919f764f
entity_id: 595faab90316f8554969e1ebb58423c2
trigger: device
conditions:
- type: is_on
condition: device
enabled: true
actions:
- choose:
- conditions:
- condition: or
conditions:
- type: is_occupied
condition: device
- type: is_occupied
condition: device
sequence:
- action: light.turn_on
metadata: {}
data: {}
label_id: eingangslicht
- wait_for_trigger:
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
timeout:
hours: 0
minutes: 10
seconds: 0
- action: light.turn_off
metadata: {}
data: {}
alias: "Steuerung: Eingang"
- conditions:
- type: is_on
condition: device
sequence:
- action: switch.turn_on
metadata: {}
data: {}
label_id:
- gartenlicht
- garagenlicht
- wait_for_trigger:
- type: turned_off
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
timeout:
hours: 0
minutes: 10
seconds: 0
- action: switch.turn_off
metadata: {}
data: {}
label_id:
- gartenlicht
- garagenlicht
alias: "Steuerung: Garten"
- conditions:
- condition: and
conditions:
- type: is_occupied
condition: device
- type: is_on
condition: device
sequence:
metadata: {}
data: {}
label_id: garagenlicht
- wait_for_trigger:
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
timeout:
hours: 0
minutes: 10
seconds: 0
metadata: {}
data: {}
alias: "Steuerung: Garage in"
- conditions:
- type: is_on
condition: device
sequence:
metadata: {}
data: {}
label_id: garagenlicht_draussen
- wait_for_trigger:
- type: turned_off
trigger: device
for:
hours: 0
minutes: 3
seconds: 0
timeout:
hours: 0
minutes: 10
seconds: 0
metadata: {}
data: {}
alias: "Steuerung: Garage"
mode: single
