Gas boiler heating thermostat using Sonoff switch
I am trying to figure out how I can make my gas boiler smart and integrate with a Generic thermostat in HA, but I am unsure how to make the connections.
My boiler has 2 connections on the board (TH1 / TH2) that the manual says is used for connecting an external thermostat, that are currently bridged with a small cable between them closing the loop. I was thinking of putting a Sonoff ZBMINI (No neutral) between the connections and be able to turn on/off the heating and make the switch control the thermostat. However, I am unsure if the connections are powered already or if I should supply 230V to the connection.
I would appreciate if someone could firstly validate my thinking and also take a look at the manual give me some advice.
The manual for the boiler is
https://files.izi-by-edf-renov.fr/files/catalogue/produits/notice-installation-acleis-elm-leblanc.pdf
It is in French, but page 20 has a diagram that may be sufficient
The Sonoff manual is here
https://sonoff.tech/wp-content/uploads/2022/12/说明书-ZBMINIL2-V1.0.pdf
Any help would be appreciated
Personally, I think you should use a switch with so-called dry contacts to connect TH1 and TH2 together.
The “dry contacts” are completely separated from the 230V.
afbeelding
Thanks,
Could you please expand a bit on how this switch differs from the switch I have and how I would connect this up ? I am not really sure what a “dry contact” is to be honest
The sonoff you are suggesting using is switching 220v (or whatever you mains voltage is) Your boiler just just needs a switch which will connect th1 and th2, or disconnect them. So a relay across th1 and th2 will do it. Don’t put mains voltage across them, the magic smoke will escape if you do.
I don’t think you want 230V on contacts TH1 or TH2, because 230V can blow up your boiler.
Dry contacts are separated from the 230V, so you can connect the contacts to this switch with confidence, without destroying everything.
Got it,
So the switch on the picture, I would connect it to 230V to power it and then the dry contact connections will open/close the TH1 / TH2 ?
Also, what make/model is that switch or any suggestions on what to buy ?
Thanks !
https://www.aliexpress.com/item/1005005440527555.html
Does this switch work without neutral (I haven’t got one…) ?
No.
It needs a Life and Neutral wire.
