Gate control (garage door) with pulse and sensor
I have done thorough searching but maybe search the wrong way.
I currently have the garage door plugin running in Vera. I want to move that to homeassistant.
I have a gate that opens and closes with a pulse. The pulse is given by a zwave qubino switch (few seconds). There is also a door sensor attached to the gate (open or close). The switch and the sensor are available in homeassistant. Currently also the “virtual switch” created in vera is available and thats what I use.
Wat it does. If I open it, it opens the gate. It checks if it is opened (sensor) and if not in ~10sec, it tries again. And the same for close. (The local security sensor might have kicked in).
Where can I find an example or help to recreate such a virtual device/ switch to mimic a gate switch combined from a pulse switch and door sensor to control my gate via homeassistant?
Later on if I decide to move away from Vera or zwave I can then also more easily replace the zwave stuff with others (for later :-)).
Thanks!
