As i already mentioned above, something like “canvas gauge card” replacement would be definitely a very good idea, since card is getting old and i have the feeling that it’s not maintained anymore…
Sorry for the OT, what do you use to monitor this data? I use a Garmin 24/7, but I haven’t found a reliable integration to recover the data.
I use Whoop with a Whoop 4.0. You can try use your home assistant companion app and see what health sensors your Garmin is transmitting to Google Fit through Health Connect. Turn the sensors on in the HA companion App.
For those looking for “canvas gauge card” replacements. This could be your answer.
Sorry @Miura for cross posting this but it does look good for those after that style.
Miura I am not sure how hard it would be to achieve but when showing either the main or secondary gauge as ‘severity’.
It would be nice if the track could be coloured in a darkened gradient that is set, not just black or white.
Serverity
Needle
Very bad render of what I mean
This sort of effect
Looks like a good feature, will look into it
Hi everyone,
I am working on fixing this bug which is about the (inter-)actions that are not working on mobile/touch devices. I have created a ‘development-release’ (pre-release) with a fix, however, the changes I had to do are very large. So I’d like to be sure it’s working for you ‘all’ before I commit to this change, as reverting will be a pain in the ***.
You can download the version - v1.5.0-dev1 - in HACS by manually ‘Redownloading’ the card and than select v1.5.0-dev1 (pre-release). Please test the extra interactions for Primary value-text, Secondary value-text and Icon - using the tap, hold and double-click actions. Also make sure the regular card-actions still works
- Please test on both desktop and mobile devices.
Your effort is greatly appreciated, thanks in advance!
Edit: little ‘btw’, you should be able to safely revert back to 1.4.0 by Redownloading again
- Benjamin
@Miura just looking at the from and pos and the possibility of automatically calculating the shift of colours between, to match expected behaviour;
If gradient: false the color stop is at the start of the segment from:
gradient: false
segments:
color: gray
colour: dodgerblue
If gradient: true the color stop is at the middle of the segment pos:
gradient: true
segments:
- pos: 0
color: gray
- pos: 12
colour: dodgerblue
CURRENT BEHAVIOUR
If
gradient: falsethe segment color stop isfrom: -
Color stop is in blue where I expect it
If
gradient: truethe segment color stop isfrom: -
Color stop shifts to the mid point and not where I expect it
If
gradient: falsethe segment color stop ispos: -
If
gradient: truethe segment color stop ispos: -
POSSIBLE SOLUTION
from:andpos:are useful to differentiate your colour stops within the yaml code but they don’t actually change the behaviour of colour stops. -
Personally my brain works with
If I set
gradient: trueand segment colorpos:needs to calculate the midpoint between myfrom:setpoints -
Maybe making
gradient: trueorgradient: falseis what changes how thefrom:is calculated (calculate mid points between thefroms:) and get rid ofpos: -
or
Making
pos:in segments specific togradient: truewhich performs a calculation on the midpoints. -
Just understanding the behaviour gives the results I need but just thinking of a way to make the card do it automatically?
Need to update docs to show *.yaml examples of how to nest the new functions.
min/maxindicators- Improve setpoint options - Implement inner setpoint
- Customizable shapes
- Add gradient backgrounds for severity gauges
is there a way to customize this into a straight bar gauge? been on the hunt for this feature
https://www.reddit.com/r/homeassistant/comments/1lwe3b8/thermostat_card_iso/
Try this
Would it be possible for the inner gauge to display the current range that the sensor is in? For example, I have a card displaying the current UV index. I’d like to know how close we are to breaking into the next group (0-3, 3-6, 6-8, 8-11, 11+). The gradient effect is great, but I’d also like to add an inner bar similar to the third image in the advanced customization configurations. So that if the current value is 5, there is a bar that displays yellow and the same size as the 3-6 range in the main gauge.
type: custom:gauge-card-pro
entity: sensor.pirateweather_uv_index
visibility:
- condition: state
entity: input_boolean.show_uv_card
state: "on"
- condition: numeric_state
above: 0
segments:
color: green
color: yellow
color: orange
color: red
color: purple
needle: true
gradient: true
titles:
primary: UV Index
gradient_resolution: medium
max: 15
value_texts:
primary_unit: " "
Just put a inner gauge in with gradient: false
For further refinement you can make the seconday text state your ranges, instead of the secondary value i.e. (0-3, 3-6, 6-8, 8-11, 11+)
You would use the same sensor data for both secondary and primary gauges.
You may also be able to modify some of my templates located in this post
(Sorry for the late response
) - I’m not sure if really following your ‘problem’ correctly. I definitely understand that gradient: true in combination with from: segments can be somewhat confusing to understand. Inspired by your post earlier I introduced pos. Configuring with gradient: true, pos tells you exactly where your color will be, so there’s no need to calculate a mid-point between the two segment.
I could indeed change the logic for gradient: true with from to work with mid-point, but I feel that’s too much complexity while pos pretty much solves the problem (imho
@miura - As shown in Gauge Card Pro 🌈 - #128 by Chykan using either from: or pos: colour stops show exactly the same behaviour.
Essentially just a different name to achieve the same thing, there is no behaviour difference between
When editing a card I know what my colour stop ranges are to be e.g. 0, 5, 10, 15, 20
If I am editing a dashboard and trying to decide if gradients or segments will look better with that particular gauge when switching between
gradient: trueorgradient: false, I need to now manually calculate my colour stops. -
I have to manually change the colour stops between the two no matter if it is
from:orpos:gradient: false= 0, 5, 10, 15, 20 (where I want the colour to start from)gradient: true= 2.5, 7.5, 12.5, 17.5 (mid point position, manual calculation)
OPTION 1
This option still involves the user to manually change the colour stops
- Delete
gradient: true or falseas an option in the card - Instead,
from:orpos:is what turns on the gradient feature.- ‘from:’ =
gradient: false- (where a user expects the colour to start)
- ‘pos:’ =
gradient: true- (which is the manually calculated mid point of where the user wants the colour)
- ‘from:’ =
OPTION 2
This option the card calculates the colour stops for pos:
- Keep the
gradient: true/falsetoggle in the card. - Introduce a distinction between
from:andpos:: from:(default) uses your defined stops directly (0, 5, 10, 15, 20).pos:triggers automatic midpoint calculation for gradients:
segments:
becomes—when using pos:—
segments:
- pos: 0 # card calculates midpoint at 2.5
color: red
- pos: 5 # card calculates midpoint at 7.5
color: green
- pos: 10 # card calculates midpoint at 12.5
color: blue
No need for users to manually compute midpoints—it’s done for them.
What I feel like something I could add is actually the other way around. from will calculate midpoints, as ‘from’ indicates a range. pos will always be the exact position where that color will be shown.
Currently I’m testing adding a from_segments_as_midpoint variable, with the idea that in the future this will be the default behaviour for from-segments (which will than also remove this from_segments_as_midpoint variable)
Hi, I’m definitely doing something wrong. I don’t have complex requests, it would seem simple, but I can’t get a title.
This is the code, where am I wrong? Thanks
type: conditional
conditions:
entity: sensor.import_power
above: -1
card:
title: Assorbimento
unit: ""
needle: true
min: 0
max: 3300
gradient: true
segments:
color: green
color: yellow
color: orange
color: red
Use:
titles:
primary: Assorbimento
Also available within the visual editor under Titles
Ok. Yes from a card standpoint I can see how ‘pos’ indicating the exact position of the colour makes sense. but from a real world perspective, people know the ranges that they want being ‘from’ and ‘to’. Pos in this case becomes something the user has to calculate between their known ranges.
That’s what I feel pos has to be. You have to set the exact position you want the colour to be.
Having from to automatically calculate midpoint makes more sense for me. See the image below. from clearly indicates the range from 50 to 75 to be yellow. That’s how the regular HA gauge works and my card without gradient also works. People who than switch to gradient: true will see that the gradient better resembles the ‘regular’ gauge, but just applied with a gradient.
