GE Enbrighten Z-wave Integration
I am attempting to pair my new GE Enbrighten switch. I have HA running on a Raspberry Pi 4 with a Aoetec Z-wave plus USB stick. This is my first Z-wave device on my network.
The light switch is installed and properly working. I went to the add my Z-wave JS integration for device inclusion.
When attempting to pair the switch by starting the inclusion and pressing the switch, HA goes back to the Start Inclusion screen. If I start an inclusion, it times out after about a minute or so without pairing the switch as expected. When I try to pair the switch, the inclusion attempt immediately stops and returns to the Start Inclusion screen. To me this indicates that the device is communicating, but an error has occurred. I checked my logs and then are no log entries to debug.
Suggestions?
What Z-Wave integration are you using?
You should check your devices. It may have been added. With what I’ve seen with zwave js, when you pair a device, there is no acknowledgment; but the device has been added.
I know that using the zwavejs2mqtt control panel, it shows the status. I am just getting back into HA after being over at openHAB for a while. This is my current test system with a mix of battery & mains powered devices…
